Old 08-09-2006, 11:26 PM   #1 (permalink)
blademast3r's Avatar
Question Processor temperature
HI guys
Basically i hav a p4 2.4 ghz procci (533 mhz fsb) which i recently oc'd to 2.53 ghz...when i see the processor temperatue from the bios menu, it shows it around 50 deg...but when i use everest 2006 it shows the temperatue around 34 deg...which one is right?? is there a software which shows the procci temp while gaming?? what is a safe range for the processor temp??
blademast3r is offline
Old 09-09-2006, 08:06 AM   #2 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
Default Re: Processor temperature
generally...the proc temp shoots up when u enter the BIOS
not a case of concern....normal range should be arnd...40-65 degrees
i think wat everest is showin is the mobo temp...pls check it again
for checkin temp i use speedfan
vijay_7287 is offline
Old 09-09-2006, 08:55 AM   #3 (permalink)
deathvirus_me's Avatar
RU sure about this ???
deathvirus_me is offline
Old 09-09-2006, 09:29 AM   #4 (permalink)
dOm1naTOr's Avatar
ya really while entering bios the temp shoots up nd will not reduce if idle in bios. Check this by frequent restarts nd entering nd restart again. The cpu will reach its max temp.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 09-09-2006, 11:01 AM   #5 (permalink)
Yes in case of an A64 with C&Q enabled, becasuse while in Bios, the processor will be running at max speed. Other cases, I dont know!
V.Prem Kumar
janitha is offline
Old 09-09-2006, 04:03 PM   #6 (permalink)
Nope its my procci temp in everest...is there any software which shows temp while playin any game?
Old 09-09-2006, 06:18 PM   #7 (permalink)
dOm1naTOr's Avatar
i think u can record the readings using riva tuner.
G3: XPS M1530 |
FZ 16.
Old 09-09-2006, 06:35 PM   #8 (permalink)
yogi7272's Avatar
dont rely on bios temp .. it always shows high readings.. mine 3.2 e is like 10 degress high in bios .. use speed fan to monitor ur temps..
yogi7272 is offline
Old 09-09-2006, 09:34 PM   #9 (permalink)
samrulez's Avatar
yes......usually XP with system idle process...optimeses the temps....but the difference is just be 'bout 8 degs, (max)....
My observations procey....BIOS 47-48.....XP....42-43 degs...........
But in u r system a diff. 10-15degs+ sounds riskey!
Also try mobo. monitor...more detailed....even gives option to set an Alarm temperature......
Sam :D Rulez :lol:
samrulez is offline
Old 09-09-2006, 10:38 PM   #10 (permalink)
Whats the threshold for mobo temp..my mobo is asrock m266a
my mobo temp is aroung 37..
Old 09-09-2006, 11:37 PM   #11 (permalink)
hi
Neither ur everest 2006 temp is showing real nor the bios temp,
37 degrees is ur mobo temp...cant be any processors temp.(esp.2.5ghz)
I also had same probe, my bios temp showed 64degrees which shocked me & my dealer made me know the whole thing as he is just a frnd of mine, so cool down...
I guess ur processor temp @ idle must be 40-45 degrees.
Intel Pentium triple3core 5.5Ghz intel original D502 GCCL Mobo 50 Gb DDR-4RajaPathar 2048Mhz 40 TBHDD EX12500XFX2GbDisplay SonyBlueRay+/-RW80.5GB
return_of_vengeance is offline
Old 06-10-2006, 10:52 AM   #12 (permalink)
[ashX]'s Avatar
Hi,
I used SpeedFan frm www.almico.com/speedfan.php
Which has inbuilt Most Useful Functions including OverClocking!
-[ashX]
[ashX] is offline
Old 06-10-2006, 11:34 AM   #13 (permalink)
gooby pls
Third Eye's Avatar
My processor temperature is 66.0 Degree Celcius.Is this right temperature ?
Third Eye is online now
Old 06-10-2006, 11:42 AM   #14 (permalink)
samrulez's Avatar
Is this @ load??? u have a 3200+ naaa?? if its at load then its a little above normal .... but if its idle then its abnormal!!! the heat sink is not touching the processor well....so u better get it fixed or u will end up frying u r procey!!!
Sam :D Rulez :lol:
samrulez is offline
Old 06-10-2006, 02:49 PM   #15 (permalink)
gooby pls
Third Eye's Avatar
I have Intel P4 3.0GHz 630,sometimes in apr-may month,the temperature reached very high i.e,93-95 degree celcius,i am not kidding,when i touched the processor,it was very hot.
Old 06-10-2006, 05:32 PM   #16 (permalink)
[ashX]'s Avatar
Cool Re: Processor temperature
Hey Man
Thats not right!
U need to cool down that and U also ...
Is this normal temp i.e. At Ideal Condition?
My PC Faced SAME Problem!
I also NEED A SOLUTION cooooooooool down my PC MAN
-[ashX]
[ashX] is offline
Old 07-10-2006, 09:20 AM   #17 (permalink)
samrulez's Avatar
no its above normal......most probably the HSF is not properly mounted.....get it fixed....for the single Prescott 65 degs should be the max at load...
Sam :D Rulez :lol:
samrulez is offline
Old 07-10-2006, 09:46 AM   #18 (permalink)
gooby pls
Third Eye's Avatar
What is HSF ?
Old 07-10-2006, 02:16 PM   #19 (permalink)
Heat Sink with Fan
V.Prem Kumar
janitha is offline
Old 07-10-2006, 05:40 PM   #20 (permalink)
gooby pls
Third Eye's Avatar
My HSF is pure c**p.will i buy new fan for processor ?
Old 07-10-2006, 06:13 PM   #21 (permalink)
samrulez's Avatar
Original fans may not be available...befor getting a new fan....remove the HSF and remount to with some Arctic Silver 5.........
Sam :D Rulez :lol:
samrulez is offline
Old 07-10-2006, 06:23 PM   #22 (permalink)
gooby pls
Third Eye's Avatar
Okay what about the price ?
Old 07-10-2006, 09:16 PM   #23 (permalink)
how much does arctic silver 5 cost and what bout availability
Old 07-10-2006, 09:44 PM   #24 (permalink)
samrulez's Avatar
~500 bucks.....its available at most of the comp shops....atleast in mumbai....
Sam :D Rulez :lol:
samrulez is offline
Old 08-10-2006, 02:00 AM   #25 (permalink)
i got it for 430 bucks in Baroda
Old 08-10-2006, 07:38 AM   #26 (permalink)
Is it worth spendin abt 500 bucks on somethin that looks like toothpast2
i mean ,how effective is it really??
Old 08-10-2006, 01:56 PM   #27 (permalink)
samrulez's Avatar
naa.....its very imp.....even though its expensive.....everyone should thermal paste.....
But if u don't wanna spend 450 bucks then....u can try out other local thermal pasts....which r cheaper,,,but r not as effective....
Sam :D Rulez :lol:
samrulez is offline
Old 08-10-2006, 08:53 PM   #28 (permalink)
Fast 'N' Furious
topgear's Avatar
Post your problem in right forum. There is a sticky thread based on in in the
Forum:
Overheating problems
topgear is offline
