08-09-2006, 02:51 PM
Level 96 Headbanger
How to Degauss monitor?
Can anyone tell me how to degauss my monitor? My monitor shows up as default monitor in the Display Settings. Originally it is a Vintron 15'' monitor, but has no option to do so.
Also, can you tell me if there is a software to do so?
"Words meant to dwell in darkness shall never see the light of day.
Words can be broken, so can bones. Execute the mandate." :twisted:
Steam : DeathMetal
Garena : death_metal27
My Blog : The Pandemonium (Latest Post : Where does music come from?)
Guitar gear : GB&A (acoustic), ESP LTD-M50 ( New :twisted:), Roland MicroCube Amp.
08-09-2006, 03:04 PM
Re: How to Degauss monitor?
You don't need software. You can do it through monitor buttons. Goto the menu and goto a section which MAY be named special or misc. You'll find the degauss option there.
08-09-2006, 03:10 PM
Level 96 Headbanger
My monitor doesnot have a menu button. It simply has the buttons to select the various options and a +/- button to adjust. So everything has to be adjusted from the front of the monitor itself.
Steam : DeathMetal
08-09-2006, 04:04 PM
gooby pls
Your monitor doesnot have menu button ?
You can also degauss via driver,tell me what do you have chipset or graphic card.
08-09-2006, 04:30 PM
Level 96 Headbanger
I have onboard Intel i82810 graphics.
Steam : DeathMetal
08-09-2006, 04:38 PM
gooby pls
You can degauss via driver properties,check the degausss in driver properties,you will find it.
08-09-2006, 04:40 PM
Beware of the innocent
if you only have options and +/- buttons, you can degauss by a combination of the buttons. Try the brightness and contrast buttons together. Or try experimenting with combinations (or RTFM)
Life is too short. Have fun.
07-10-2006, 11:41 AM
Level 96 Headbanger
There isnt any option to in the driver properties.
Can anyone suggest any software that can invoke my motherboard to do it?
Steam : DeathMetal
07-10-2006, 11:58 AM
gooby pls
Check the drive properties throughly,you will find it.
07-10-2006, 12:12 PM
Google Bot
Only a physical degauss wd do good.. Not thru ne software
12-10-2006, 02:23 PM
Tux Fan
Get intel's latest drivers. Go to graphic properties. navigate around the menus you will surely find it.
Cheers
Shaunak
Feel free to PM/email me.
12-10-2006, 03:00 PM
Welcome To The Jungle
yes try do it physically.
Me n My Canon EOS 350D with EF 50mm f1.8
12-10-2006, 03:33 PM
UBERGEEK
If u have an LG Monitor then the degauss button is there in the settings display
of the monitor.....i think there is no medium of Degaussing by the help of any software or latest drivers..
And here comes the crysis killer: http://in.youtube.com/watch?v=Cd-LPHZcLNQ
13-10-2006, 04:22 AM
i think as u have an old monitor it must not be supporting the degauss function.
but as ilugd told try some combinations of keys or if u have its booklet refer it.
Intel Pentium triple3core 5.5Ghz intel original D502 GCCL Mobo 50 Gb DDR-4RajaPathar 2048Mhz 40 TBHDD EX12500XFX2GbDisplay SonyBlueRay+/-RW80.5GB
06-12-2006, 12:45 PM
Level 96 Headbanger
My Uncle tells me this trick:
To degauss a Monitor, keep it cold (such as by keeping it off overnight). When you put it on the next day in the same state, the monitor automatically gets degaussed.
What do you think (or say)?
Steam : DeathMetal
06-12-2006, 06:11 PM
Well, logically it shouldn't, but maybe if you do it in faith, it should happen.
