LinkBack (8) Thread Tools Display Modes
Old 20-04-2005, 10:56 AM   #241 (permalink)
SymbianGeek
Hi,
Can somebody tell me whats the price of a decent medium sized
ATX cabinet?
--eminemence.
eminemence is offline   Reply With Quote
Old 20-04-2005, 12:13 PM   #242 (permalink)
i got an ibox less smps Rs 800/-
**** happens
pradeep_chauhan is offline   Reply With Quote
Old 20-04-2005, 02:40 PM   #243 (permalink)
Ethan_Hunt's Avatar
Originally Posted by krishnathelord
can help me with price of sli mobos (Asus and msi ones) pls give model no. also
That would be the Asus A8N With SLI Support which retails around 12-13k Out here in Mumbai And as for the Intel SLI Isnt available out here
V for Vendetta
Ethan_Hunt is offline   Reply With Quote
Old 20-04-2005, 06:19 PM   #244 (permalink)
harish_21_10's Avatar
hi,
Just need the prices of the following phones:
1.3230
2.6630
3.7710
tnx
NOBODY is PERFECT and i am NOBODY
harish_21_10 is offline   Reply With Quote
Old 21-04-2005, 12:10 PM   #245 (permalink)
Geforce's Avatar
My System specs r:
AMD Athlon64 2800+
MSI K8N Neo Platinum
512MB DDR400 Kingston
Geforce4 Ti4200
One of my Friends is coming from US, he asked me if i wanted something from there. I don't want to upgrade my GFx card right now.
I was thinking to get another 512MB RAM as it would only cost around 2300/- as compared to 4000/- for kingston totaling the system RAM to 1GB.
Will it make much of a difference in games. I play far cry, DOOM3, HL2 and it seems to run pretty well on 512MB.
Should i go for it.
Geforce is offline   Reply With Quote
Old 21-04-2005, 12:39 PM   #246 (permalink)
Originally Posted by Geforce
My System specs r:
AMD Athlon64 2800+
Geforce4 Ti4200
Should i go for it.
Will make a world of a diff in the load times and will boost your frames if you have the right card. Dump the Ti4200 and get a 6800GT or 6600Gt from the US. Just my opinion though.
www.techenclave.com Ecumenical Technology !:)
blade_runner is offline   Reply With Quote
Old 21-04-2005, 04:53 PM   #247 (permalink)
Default hi
Can anyone please post the latest list of Graphics Card prices for AGP and PCI Express
mako_123 is offline   Reply With Quote
Old 21-04-2005, 06:35 PM   #248 (permalink)
Geforce's Avatar
Well the difference between the rates in India and US is enormous. You can get a Geforce 6800 GT for 12-13k ... it is very tempting.
Even though I can afford it ... i won't buy it ...'cause Ti4200 is giving good frame rates in recent games right now with good special effects reproduction.
I would rather jump to an even bigger leap - to the next generation chip .... the nividia G70 or something.
Old 21-04-2005, 07:41 PM   #249 (permalink)
Ethan_Hunt's Avatar
Default Re: hi
Here Check this out
http://www.thinkdigit.com/forum/view...=asc&start=180
V for Vendetta
Old 22-04-2005, 12:14 PM   #250 (permalink)
The pWnster
Vyasram's Avatar
Hi
Can you tell me how much would the following config costs
AMD Athlon 939pin 3000+ / 3200+
MSI K8N Neo 4 Platinum
Hynix 512mb DDR RAM 400 Mhz
Samsung / Seagate 160GB SATA HDD
VIP 400W SATA Power Supply
XFX 6600 256MB Graphics
VIP ATX Cabinet
Sony DRU 710A DVD Writer
Sony 16/52 DVD ROM
Sony 1.44mb FDD
Creative Inspire 5200 Speakers
Samsung 793s 17" Monitor
Logitech elite keyboard
Logitech 3 button optical scroll mouse
56k internal modem(any good brand)
Compro Tv Tuner/Capture/fm
Logitech Quickcam Express
HP PSC1315 all in one
Decent Quality Headphone and mic
PLease tell me the price of this config as i want to buy a new pc
Also tell me what ups should i buyfor this power supply and its price(preferably apc or wipro)?
Vyasram is offline   Reply With Quote
Old 22-04-2005, 12:15 PM   #251 (permalink)
The pWnster
Vyasram's Avatar
Also tell me what ups would be necessary for this power supply
Old 22-04-2005, 07:19 PM   #252 (permalink)
additonal 512mb may not give you much help for palyabitlity in games like doom3 as yuo cn anyways not play at ultra high quality settings.
Also,if you are so content with your card, could you please tell whether depending upon the game and map you are able to get 30-60fps and above in games like :
doom 3
half life 2
far cry
ut2004
splinter cell : chaos theory
hitman contracts etc
@ 1024*768,med-high quality settings,not highest quality
akshayt is offline   Reply With Quote
Old 22-04-2005, 07:21 PM   #253 (permalink)
also, kingston value ram should cost 3200-3300 and not 4000
corsair is for 3400 + 4% vat in delhi and also kingston nowadays in india , have heard that don't know which chip you would get so rather go for transcend or corsair ask others about compatibility.
Old 24-04-2005, 01:39 AM   #254 (permalink)
Can anyone suggest Which Graphics card should i buy for a PCI -ex motherboard. My budget is around 9000.
\" I Do not like to repeat success , i like to move on to other things \"
Old 24-04-2005, 05:36 AM   #255 (permalink)
i want to buy geforce 6600gt graphic card.i have seen that there is not much price difference betwen the agp & pci express varient of the card.so i have decided to go for the pci express by upgrading to a motherboard which supports a pci express slot.
so please suggest me a good motherboard for intel processor. [BRAND PREFFERED"INTEL"]
my current pc config is:
procesor: p4 2.4
motherboard: intel 845gebv2 [agp 4x]
ram:256 mb ddr [266 mhz]
I DONT WANT TO UPGRADE RAM & PROCESSOR.I WANT A DESCENT MOTHERBOARD TO MAKE MY SYSTEM FUTUREPROOF COZ PROCESOR & RAM CAN BE CHANGED WHENEVER WANTED.ALSO MENTION THE PRICES.
nothing is impossible
even the word IMPOSSIBLE says
\"I M POSSIBLE\"
monty701 is offline   Reply With Quote
Old 24-04-2005, 03:16 PM   #256 (permalink)
Why is XFX PCX 6200 Priced less than Geforce 5700 . Which one is better, i mean 6200 has got better shader model etc so why is it priced less. Is it not better than 5700 ?
Old 24-04-2005, 10:48 PM   #257 (permalink)
hey guys,MY CURRENT CONFIG IS:
procesor: p4 2.4 [533mhz]
ram:256 mb ddr [266 mhz].
now i want to buy a 6600 gt graphics card.i have seen that there is not much price difference between the pci-e & agp varient.also the pci-e technology is latest & better.
so i want to upgrade my motherboard & cpu.i want a motherboard which supports pci-e slot.i would prefer AMD 64[socket 939] cpu and an appropriate motherboard.so kindly give me the list of various cpu & motherboard combos good in performance as compared to my existing combination.also mention the prices.what price shall i get if i sell my current cpu & motherboard???help required urgently...
\"I M POSSIBLE\"
Old 25-04-2005, 03:35 PM   #258 (permalink)
Get a AMD64 3000+ for 7k or 3200+ for 2.5k more and the MSI Rs480 which seems to be the cheapest pcie mobo arnd for 5.8k. The performance difference b/w ur current setup and the new one shud be a lot since you dont have a gpu. Also get a Gb if ram if you are gonna be playin the latest games like d3 and hl2 etc.
Old 26-04-2005, 02:53 AM   #259 (permalink)
hey guys what r the prices of following motherboards in mumbai
1. ASUS A8N-SLI Deluxe (NVIDIA nForce4 SLI)
2. MSI K8N Diamond (NVIDIA nForce4 SLI)
3. Gigabyte GA-K8NXP-SLI (NVIDIA nForce4 SLI).
*** ALSO WHICH IS BEST AMONG THESE?????***
help fasst......
\"I M POSSIBLE\"
Old 26-04-2005, 01:04 PM   #260 (permalink)
geek_rohit's Avatar
Mobile Phone Price List
Mugdha Roge
Here's a list of mobile phone models and prices sourced from a few authorised dealers in Mumbai. All prices are maximum retail prices (MRP), except where indicated otherwise.
Note: Nokia, Samsung and Sony Ericsson prices have now been updated as of 25th April 2005.
Source
SportZForumZ - We Know Your Game Better
http://www.sportzforumz.com
My Site & Blog
http://www.rohit-sharma.com
geek_rohit is offline   Reply With Quote
Old 28-04-2005, 11:07 AM   #261 (permalink)
thanks buddy
abhinav is offline   Reply With Quote
Old 28-04-2005, 11:09 AM   #262 (permalink)
also tell me the latest price of RAM any local
Old 01-05-2005, 11:18 AM   #263 (permalink)
WHiCH Mid range MotherBoard N proceesor Along with Display card wuld be good enough to support DDR II ,, pci exp,, ???
AMD prefered
Y isnt DDR II much in discussion here ? is it not worth or not available in mumbai ?
suhas_sm is offline   Reply With Quote
Old 01-05-2005, 07:03 PM   #264 (permalink)
Ethan_Hunt's Avatar
AMD prefered
Hmmm.....Well PCI-E For Amd Processors are very few Namely Asus A8N And K8N DL Mobo which are very high Priced.As for Intel's Line up its quite simple a 2.8Gigz Proccy and a 915G Original Mobo(PCI-E With Onboard Intel GMA900 Graphics)will Cost Ya round 14k and yup this Mobo supports Dual Channel DDR 2 Memory (DDR2 533MHz and DDR2 400Mhz Frequencies).DDR 2 is relatively a new standard and very few people seem to be aware of its use and yes its definetly worth it and possibly available in Mumbai too.
V for Vendetta
Old 02-05-2005, 08:16 AM   #265 (permalink)
Location: heaven doesn't want me and hell's afraid i'll take over
anyone from chennai who can give me the prices of the xfx geforce 6600 range in ritchi?? also the prices of the amd 3000+ and 3200+ ??//
sandeeprao is offline   Reply With Quote
Old 02-05-2005, 11:42 AM   #266 (permalink)
jay4u's Avatar
Default Wanted price quotes..
I wanted to upgrade my system. I want to go for a PC which would be low on my pocket and high on performance. Right nowI wanna buy
1. Mobo
2. Pocessor (optional)
3. Graphic card
4. Ram
My estimates :
1. 2.8Gigz Proccy and a 915G Original Mobo(PCI-E With Onboard Intel GMA900 Graphics)
2. 5700 LE XFX Graphic card
3. 512 MB DDR 400 Mhz RAM
Is it a good deal... 13k + 5k + 2k roughly around 20k... what do u have to day.... Suggest any better combination....
Passwords are like underwear... Change them often...
jay4u is offline   Reply With Quote
Old 02-05-2005, 04:06 PM   #267 (permalink)
 Macboy
goobimama's Avatar
Asus Motherboard + AMD64 2800 CPU = 9400
512 MB RAM (hynix) = 2400
80GB hdd (seagate SATA) = 3000
17" Monitor = 6000
KBD + Mouse (Logitech Optical Mouse) = 750
DVD Combo Drive = 2700
Cabinet (iBall brand) = 1350
UPS (iBall brand) = 1700
VAT = %4 = 1200
Warranty and delivery = 500
Total = 29000
Is this a suitable price for the config or is the dealer cheating me?
I'm like a bird... :)
goobimama is offline   Reply With Quote
Old 02-05-2005, 06:02 PM   #268 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
Default depends
17" Monitor = 6000
VAT = %4 = 1200
Total = 29000
hey it depends on which asus mobo he is giving, also please make sure how many pin processor he intends to give u, better still tell him that u want 939 pin processor. abt ram -> go for 400mhz ram. monitor-> which one? rest all seems to be fine. but be sure to collect all warranty cards and receipts to avoid any trouble. happy computing
wizrulz is offline   Reply With Quote
Old 02-05-2005, 10:06 PM   #269 (permalink)
 Macboy
goobimama's Avatar
which mobo should I ask for? I'll see about the processor. Does the 2800+ come in the 939 pin socket?
Also, it is 400 Mhz RAM,
Monitor, I think its LG or Samsung
and lastly, this is a config for my friend. If and when I buy my killer config, its gonna be a Mac...
Old 02-05-2005, 10:29 PM   #270 (permalink)
Hey guys plz help I bought 256mb ram 333mhz for Rs.1750.A week ago.
Now planning to upgrade it to 512mb ram,as i think 256 is now sufficient.Also i am low on budget and need a Graphic card with good performance.Tell me the price of all which will be better.
Money will decide afterwards means hav to buy a graphic card and dont hav any idea which one to buy.
LinkBack to this Thread: http://www.thinkdigit.com/forum/hardware-q/3584-latest-hardware-prices-quotes.html
StartHome This thread Refback 17-04-2011 06:46 AM
Philips 17' crt monitor, ? 1 - Bangalore This thread Refback 30-11-2010 05:51 PM
Opera Extensions Well the best 7 of - Online Best Latest Price Reviews | Features in India This thread Refback 17-11-2010 12:06 AM
download driver audio mainbord hyundai w5700 - Virgilio Ricerca Web This thread Refback 06-11-2010 07:50 AM
Logitech Speakers Dealer In Tamilnadu - Logitech Speakers This thread Refback 22-10-2010 11:23 PM
LATEST HARDWARE PRICES QUOTES Hardware Troubleshooting Question This thread Refback 25-09-2010 04:35 PM
transcend ddr3 ram prices | BoardReader This thread Refback 21-09-2010 02:03 PM
Nehru Palace - PC market in New Delhi - indiTraders - Forum for the Active Indian Trader This thread Refback 08-07-2010 12:11 AM
Latest Processor Prices codename_romeo Hardware Q&A 81 09-06-2009 05:56 PM
Latest prices bizzare_blue QnA (read only) 4 09-12-2008 06:52 PM
Latest prices.......... codename_romeo Hardware Q&A 32 17-11-2006 11:28 PM
Need the Latest Prices for Mumbai Am a Geek Hardware Q&A 1 06-03-2006 04:41 PM
what r the latest hardware prices in mumbai superwiz QnA (read only) 1 08-09-2004 01:54 AM
- by soumya
- by tv6952
