LinkBack (8) Thread Tools Display Modes
Old 03-05-2005, 06:51 AM   #271 (permalink)
What is the cost of ASUS A8N SLI in mumbai ???
Wat onboard display card it offers ?
Which Mid range PCI display card would be best fot it ?
Also which ram ? i want 1 GB ram .
Is mobo good for runnnig heavy software devepolment programs too ?
suhas_sm is offline   Reply With Quote
Old 03-05-2005, 07:08 PM   #272 (permalink)
Default Latest Prices
Can any one tell me the cost of following
80 GB Seagate HDD
Samsung DVD ROM
GeForce FX 5200 with 128MB RAM AGP 8X
GeForce FX 5700 with 256MB RAM AGP 8X
apoorv_bindlish is offline   Reply With Quote
Old 03-05-2005, 07:23 PM   #273 (permalink)
Ethan_Hunt's Avatar
Around 13.5k atleast.
None.Based On the Nforce 4 Chipset which aint offering any Onboard thingyy.
Budget?????
Take your Pic From Geforce 6200 Pci-E Or the Fx5700 Non-Ultra PCI-E version.Recommended would be Geforce 6600Gt PCI-E version
Kingston Or Transcend 1Gb 400Mhz @6.5k
Its the Processor that counts the most as compared to the Motherboard....If say you have a Socket 939 Processor like Athlon 64 3200+ or sometin like that on this mobo then yea it can easily handle heavy applications provided a Good Graphics card and Sufficient Memory.
V for Vendetta
Ethan_Hunt is offline   Reply With Quote
Old 05-05-2005, 07:03 PM   #274 (permalink)
msi pci-e slot, + onboard video
a8n sli shud be 12.5
<13
last was about 12750-12800 approx
corsair ddr 400 512mb
3250+ tax
try to avoid kingston,ask others
akshayt is offline   Reply With Quote
Old 06-05-2005, 02:49 PM   #275 (permalink)
dinesh_singh
Posts: n/a
Default dear friends
please guide me for buying a cpu.as i m an amd fan so will be intrested in amd only.i am intrested in athlon 64 3200+ socket 939.
the problem is i m told that winchester core is better .....i want to know that which one is the core of this cpu....i m also intrested in investing in a sli motherboard.
can u people tell me which brand shuld i go for.....at my city only gigabyte and asus are available.which should i buy.
and i m intrested in a xfx 6600gt or xfx 6800 gt....
as xfx gt6800 cost almost double from 6600gt from xfx....will it provide a double performance.or a xfx 6600gt will be sufficient.
i have 1gb kingston 400 ddr ram.
plz help as soon as possible as i will upgrade this week only
Old 06-05-2005, 11:28 PM   #276 (permalink)
3200+ on socket 939 means its winchester ( 90 nm fabrication )
6800gt is much better than 6600gt . i suggest u go in 4 a gainward card . xfx is crappy compared 2 it .
go in 4 asus a8n-sli deluxe ( dont remember if a deluxe is available or not , do check it out , i think it is ) . dont even touch gigabyte
the genius of the hole : no matter how hard u try 2 get 2 the top , 1 mistake n u start again
mamba is offline   Reply With Quote
Old 07-05-2005, 09:48 AM   #277 (permalink)
dinesh_singh
Posts: n/a
Default thanx
thanx dear.....i was going buy a gigabyte mobo....but is it really that bad.
yes asus a8n sli delux is available from rashi peripherals.
can you tell me any distributer of gainward in chandigarh.
as here only gigabyte asus and xfx cards are available.
or shuld i go for asus 6600 gt series.
is xfx 6600gt is better then asus 6600gt.
i think i have only two options here xfx 6600gt and asus 6600gt
rashi peripherals prices rs 13000 and rs 17000.
please help me choose.
Old 07-05-2005, 03:12 PM   #278 (permalink)
rates in nehru place as on 07-05-2005 (approx)
asus mobo(nforce4 250gb chipset)+amd 64 3200+(939)=12500
amd 64 fx-55=45000
xfx geforce 6200/250mb [agp 8x]=5500
xfx geforce 6800 ultra=14500
seagate 80 gb 7200 rpm SATA=2850
512 mb ddr 400 fsb=2970
u have to wander a lot in the market to get prices that low. there can be a difference of 1000 bucks on high end item b/w venders if u can find it.
for example one vender was offering asus 8n sli mobo for 16700, another one was giving it out for 13400 and yet another vendor offered it for 12200.
nashedi is offline   Reply With Quote
Old 07-05-2005, 11:55 PM   #279 (permalink)
seriously
if it aint a typo , plz tell me the dealers name
Old 08-05-2005, 02:29 PM   #280 (permalink)
oops, soorryyy it wasn't ulra. just plain 6800 and vender is skope comp.
Old 09-05-2005, 03:57 PM   #281 (permalink)
Hey guys plz help I bought 256mb ram 333mhz for Rs.1750.A week ago.
Now planning to upgrade it to 512mb ram,as i think 256 is now sufficient.Also i am low on budget and need a Graphic card with good performance.Tell me the price of all which will be better.
Money will decide afterwards means hav to buy a graphic card and dont hav any idea which one to buy.
abhinav is offline   Reply With Quote
Old 10-05-2005, 01:06 PM   #282 (permalink)
rohanbee's Avatar
Guys i have a suggestion. This thread is getting very confusing and long. I think there should be group categories so that there is no mix -up
Here we have anything and everything after a while it might get too cluttered!!
Quote by Garfield'
rohanbee is offline   Reply With Quote
Old 10-05-2005, 10:15 PM   #283 (permalink)
Default suggest a suitable motherboard
I am planning to buy a AMD300+/3200+, but need advise and cost (in Mumbai) of a suitable mother board...
Other config I have in mind is 512DDR/80GB SATA
ravibhatia is offline   Reply With Quote
Old 11-05-2005, 05:29 PM   #284 (permalink)
can some one tell me the cheapest with hardware accn and lighting for agp 8x
who the hack is this??
mukul is offline   Reply With Quote
Old 12-05-2005, 11:30 AM   #285 (permalink)
rohanbee's Avatar
Default Re: suggest a suitable motherboard
Friend there is a thread which you might like to check out also........a lot of hardware prices are being discussed there too..........http://www.thinkdigit.com/forum/viewtopic.php?t=19659
Just in case you dont get all your answers here. cheers
Quote by Garfield'
Old 15-05-2005, 09:46 AM   #286 (permalink)
256 mb ram 400 fsb=1675(13/5/2005)....nehru place.
Old 17-05-2005, 12:05 AM   #287 (permalink)
Technoholik !!
Tech&ME's Avatar
Pentium 4 3 Ghz with HT : 9000
Intel Original mobo D915GAV (Grantsdale): 5500
Kingstone Original DDR 400 RAM 256 MD : 2000 (Kingstone Dealer Price)
Prices are EX-BANGALORE Official Dealer Prices ( Not S P Road Prices )
[Desktop]
[Laptop]
Dell Studio 15 Full HD || [OS] Now with Mac OS X LION
Tech&ME is offline   Reply With Quote
Old 17-05-2005, 12:14 AM   #288 (permalink)
Technoholik !!
Tech&ME's Avatar
Which company RAM are you talking about ?
[Desktop]
[Laptop]
Old 17-05-2005, 03:32 PM   #289 (permalink)
pls give banglore prices for:
6600GT 128 mb
6600 GT 256mb
6800GT 128mb
6800GT 256mb
6600 PCI-E
6800 PCI-E
thanks
sam2211 is offline   Reply With Quote
Old 19-05-2005, 04:08 AM   #290 (permalink)
Could I have the rates of the following :-
NAGPUR<JABALPUR<INDORE(Will be preferred )
I have BOUGHT A ASUS K8N - E Delux
Transcend ddr 400 512mb
GeForce fx 5700Le with s-media 128 mb !!
AMD Athlon 64 2800+
AMD Athlon 64 3000+
AMD Athlon 64 3200+
(ALL ARE 754 pin based !!)
HARD DISKS -
SATA-
Samsung 80gb,120gb PUMA(sata)
Seagate 80gb,120gb(Baracuda)
Maxtor 80gb,120gb
UPS-
Intex 500va & 600va
microtek 500va & 600va
numeric 500va & 600va
APC 500va 600va
COMBO DRIVES -
SONY
LITE- on (if available)
ASUS
LG
SAMSUNG
DO mention where were the rates from and where it can be purchased and if u could get a numbers to dealers and distributers !!
THANK YOU ALL IN ADVANCE !!! PLZ HELP ME !!!
\"Live Life as it comes & Live it KINGSIZE\"
\"Learn From Yesterday,Live For Today & Hope For Tomorrow\".
Bye 4 Now - N_!_r_a_L
King_Niral is offline   Reply With Quote
Old 20-05-2005, 01:08 AM   #291 (permalink)
Ndivia 6600 AGP 256 Mb For Rs. 9350
Happy Computing
krishnathelord is offline   Reply With Quote
Old 20-05-2005, 09:19 AM   #292 (permalink)
i heard 256mb cards uses cheap memory components compared to 128bit...also doesnt provide any significant change is it true????
magnet is offline   Reply With Quote
Old 21-05-2005, 09:31 PM   #293 (permalink)
Default Re: Hmmm
Originally Posted by it_waaznt_me
Hmmm.. Nehru Place is the place for Delhi ppl ..
The Cost Calculator is a cool thingy they got ..
This is the crappiest site i've seen they quoted 9000 for an AMD 2800+
and the rest are +lly bad.
sagsall4u is offline   Reply With Quote
Old 22-05-2005, 11:09 AM   #294 (permalink)
Default Re: Hmmm
It is a bad site!!!! but atleast u can get hints of rates if ur not living in the metros!!!
Old 22-05-2005, 11:34 AM   #295 (permalink)
Default no no no .....
then even 9000 for an amd 2800+ is dumb and will give ppl the wrong idea
Old 22-05-2005, 11:50 AM   #296 (permalink)
Default Halp
i need the price of this mobo MSI K8N Neo4 Platinum/SLI urgently . prefers mumbai prices
Old 22-05-2005, 11:50 AM   #297 (permalink)
over here a computer guy said Rs9800 for a 2800+ !!
but u never got the point !!!
it is the rate of the COMBO PACK !!!!
coz here where is live No one sells the processor alone !!!!
CHEERS !!!
Old 22-05-2005, 11:55 AM   #298 (permalink)
Old 22-05-2005, 11:58 AM   #299 (permalink)
CHEERS !!!
what do you mean by a COMBO pack . i am quite new here i guess
Old 22-05-2005, 12:28 PM   #300 (permalink)
BY combo i mean MOBO + PROCESSOR !!!!
LinkBack to this Thread: http://www.thinkdigit.com/forum/hardware-q/3584-latest-hardware-prices-quotes.html
StartHome This thread Refback 17-04-2011 06:46 AM
Philips 17' crt monitor, ? 1 - Bangalore This thread Refback 30-11-2010 05:51 PM
Opera Extensions Well the best 7 of - Online Best Latest Price Reviews | Features in India This thread Refback 17-11-2010 12:06 AM
download driver audio mainbord hyundai w5700 - Virgilio Ricerca Web This thread Refback 06-11-2010 07:50 AM
Logitech Speakers Dealer In Tamilnadu - Logitech Speakers This thread Refback 22-10-2010 11:23 PM
LATEST HARDWARE PRICES QUOTES Hardware Troubleshooting Question This thread Refback 25-09-2010 04:35 PM
transcend ddr3 ram prices | BoardReader This thread Refback 21-09-2010 02:03 PM
Nehru Palace - PC market in New Delhi - indiTraders - Forum for the Active Indian Trader This thread Refback 08-07-2010 12:11 AM
Latest Processor Prices codename_romeo Hardware Q&A 81 09-06-2009 05:56 PM
Latest prices bizzare_blue QnA (read only) 4 09-12-2008 06:52 PM
Latest prices.......... codename_romeo Hardware Q&A 32 17-11-2006 11:28 PM
Need the Latest Prices for Mumbai Am a Geek Hardware Q&A 1 06-03-2006 04:41 PM
what r the latest hardware prices in mumbai superwiz QnA (read only) 1 08-09-2004 01:54 AM
