Old 06-09-2006, 07:09 PM   #1 (permalink)
Default Asus 5224A CDWRITER PROBLEM
Hi,
Forum members.How are you?These days my cdwriter is giving lots of errors and the model no. of mywriter is ASUS 5224A.I am getting write error and session fixation error.I am using the version 6 of NERO and using WINDOWS XP SP2 operating system.I have tried everything from reinstalling the writing software to reinstalling the operating system and also cleaning the cdwriter but all is vain.I have also tried to write at lower speeds but could not get result.I am using the latest firmware version V1.70.I have downloaded this from ASUS website.Please help me.
KompGeek
KompGeek is offline
Old 06-09-2006, 07:29 PM   #2 (permalink)
coolsunny's Avatar
Default Re: Asus 5224A CDWRITER PROBLEM
did u change ur bios setting recently?
AMD X2 260, GA M68MT-S2P, Gskill RipjawsX 4GB, 500Gb Seagate, Cooler Master eXtreme Power Plus 600W, Altec Lancing atp3, Samsung B2230 TFT, Numeric Digital 600 EX-C UPS.
coolsunny is offline
Old 06-09-2006, 07:36 PM   #3 (permalink)
dOm1naTOr's Avatar
It seems the lens/eye has gone wrong. Get it to cervice centre if under warranty or get it repaired.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 12-09-2006, 12:21 PM   #4 (permalink)
No,I didnt change my bios settings recently,but what is the relationship between bios settings and cdwritre error.Please let me know.
KompGeek
KompGeek is offline
Old 13-09-2006, 08:59 PM   #5 (permalink)
coolsunny's Avatar
dont know exactly.i hv also some some problem with my drive regarding reading particular movie dvd.it solved after resetting the bios setting & reinstalling OS.
just make ur BIOS default setting.& if it does not work,go to hardware vendor.
inform us what happened to ur drive.
