Old 06-09-2006, 06:24 PM   #1 (permalink)
Default g800gs to 6800gt........
i saw this post somewhere which stated tat i cud convert my 6800gs(agp)....to a 68000gt by unlocking two pipelines using rivatuner,,,,,,,,,
i got riva tuner and it shows tat 2 pipelines have been masked.........
i wud luv to unmask them.....but it wud affect my gaurantee right ????
and if i do unlock it....will it damage my card.......
here is the link....
http://www.aoaforums.com/forum/hardw...a-extreme.html
also it says tat if it doesnt work backup the process..........i can do tat.....
but ma question is.....will it damage my card ?????
anilthomas26 is offline
Old 06-09-2006, 06:39 PM   #2 (permalink)
Default Re: g800gs to 6800gt........
If you don't do it right it could damage your card, and yes, you do lose you warranty once you go through with this.
drvarunmehta is offline
Old 06-09-2006, 06:42 PM   #3 (permalink)
but there is nuthing much to do.....
jst unmask two pipelines using riva tuner,,,,,,,wat cud go wrong ????
Old 06-09-2006, 06:49 PM   #4 (permalink)
provided both are standard specs and 256mb, gs may be the way to go
akshayt is offline
Old 06-09-2006, 07:01 PM   #5 (permalink)
dOm1naTOr's Avatar
Just oc your GS..its far less risky than to unlock the pipes.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 06-09-2006, 07:12 PM   #6 (permalink)
and cud u tell me how to oc ???
Old 06-09-2006, 07:44 PM   #7 (permalink)
deathvirus_me's Avatar
unlocking isn't harmful .. if things go wrong , u'll just get a bsod ... then boot into safe mode , and uninstall the driver , and / or wile booting hold down control ...
Also .. i've heard that most of the nv40 GS's are unlockable .. so make sure u have the proper core before u do anything wrong .. google a bit for some successfull OC's ...
deathvirus_me is offline
Old 06-09-2006, 07:45 PM   #8 (permalink)
dOm1naTOr's Avatar
Do like this:
start/run nd type
REGEDIT
navigate to
[HKEY_LOCAL_MACHINE\Software\NVIDIA Corporation\Global\NVTweak]
right click on right open space nd create a new Dword value nd give it a value 3 and name it CoolBits
close everythin nd see the nvidia control panel for new overclockin tab. Do small increments-say 5mhz. U can surelly do bout 50mhz on core nd 100mhz on mem. After that do some 3~4 mhz per increment nd try running heavy games for min 20min.
G3: XPS M1530 |
FZ 16.
Old 06-09-2006, 10:33 PM   #9 (permalink)
and...if i overclock or unlock the pipelines/........wud i require any cooling systems ???
i wud rather prefer the unlocking process.....
and overlocking.........wud it damage the card ???
Old 06-09-2006, 11:17 PM   #10 (permalink)
dOm1naTOr's Avatar
Now yaar...todays cards are biult for overclocking. Ask deathvirus_me bout the safe oc clocks of a 6800GS.
I run my 7600GT at 600/1500 from its stock 560/1400, nd no probs. U just have to make sure there is good air flow in your cab. Im using xtra 5x80mm fans in my cab as Ive oced my, GPU,CPU and also memory by big margins.
Just place an 80mm fan on four screws on the bottom of cab facing the card nd should blow air into the card. U can do much higher clocks.
G3: XPS M1530 |
FZ 16.
Old 07-09-2006, 12:27 AM   #11 (permalink)
Well , the nv4x cores can run pretty hot .. i've seen 6800GT's run stable at 90c , 6600GT's at around 95c .. and even seen some damm oc'ed GS's touch 80c ... so u can experiment a bit ...
But even then make sure u have good airflow in the cabinet ...
Old 07-09-2006, 01:03 AM   #12 (permalink)
dOm1naTOr's Avatar
I can't believe it...95c...My G72 had not yet crossed 58c nd even Im afraid.
G3: XPS M1530 |
FZ 16.
Old 07-09-2006, 09:04 AM   #13 (permalink)
proper core...????
i dint get ya......:d
__________
Originally Posted by aravind_n20
Do like this:
start/run nd type
REGEDIT
navigate to
i did this.....and an extra tab named "clock frequency settings" opened up
it says core clock frequency = 400mhz
memory clock frequency = 1.1ghz
shud i just increment a bit each.......nd how much ?????
and the important thing ......will my gpu burn out or something ?????
is it reversible ???
__________
sry but one more......
can i unlock the pipelines and overclock at the same time ????
Last edited by anilthomas26; 07-09-2006 at 09:04 AM. Reason: Automerged Doublepost
Old 07-09-2006, 02:57 PM   #14 (permalink)
dOm1naTOr's Avatar
Ya its reversible. first di some 20~30Mhz on core nd some 50~80 on mem nd play some heavy game for 20min nd see if there is any aartifacts or any hangs. If its ok u can go on with the setting or try some more oc.
G3: XPS M1530 |
FZ 16.
Old 07-09-2006, 08:32 PM   #15 (permalink)
hey i tried unlocking the pipelines.....
wheni unlock the pixel pipelines........the screen is full of artifacts..so i had to disable them.....but i did enable the vertex pipeline........
so now i have 12pp and 6vp......
and now i am gonna overclock it.......
__________
overclocked to 425mhz/1.15ghz.......
shud i do more ???????
Last edited by anilthomas26; 07-09-2006 at 08:32 PM. Reason: Automerged Doublepost
Old 08-09-2006, 12:34 AM   #16 (permalink)
Well every core is different ... my nv42 goes about 70c under max load ... even though its a 130nm manufactured one's ... older core's can go even higher ...
Old 08-09-2006, 01:34 AM   #17 (permalink)
dOm1naTOr's Avatar
Y my old MX440 is just hot as a diesel engine. And even then it has no heatsink but only a fan. It can't say the pemperature-but Im sure it was above 100.
G3: XPS M1530 |
FZ 16.
Old 08-09-2006, 07:59 AM   #18 (permalink)
so.....shud i go for more ?????
and shud i fix some new fans or something ?????
and wat is stock cooling ???? and how much will it cost ????
Old 08-09-2006, 08:02 AM   #19 (permalink)
stock cooling is the cooler thats already covering the ram and core of the card ...
And , some additional fans would definitely be a good thing to do ..
Old 08-09-2006, 08:04 AM   #20 (permalink)
80mm ya 120mm ????
actually i have left ma cpu cover open !!!!
shud i try overclockin some more .....now its at 425/1150.......(400/1100)...
i wud like to......but the prob is tat.......i will di it only if it is a bit safe....coz if i burn this one out i wint get a new card in the near future.....
Old 08-09-2006, 09:59 AM   #21 (permalink)
dOm1naTOr's Avatar
Its better go for 120mm if ur cab supports it. Fix an 80mm fam on four long screws on bottom of the cab so as to face nd push air to the gcard nd in that way u can go even higher.ways beeter than an 80mm as it pushes more air with less noise, but your cab has to support it.
Jus t attach or place an 80mm fan on for long screws on the bottom of your cab so as to push air to the Gcard, u can go for much higher oc.
G3: XPS M1530 |
FZ 16.
Old 08-09-2006, 10:10 AM   #22 (permalink)
wat do u mean by "support the fan " ?????
i just have to connect it right to a power sorce right ?????
and look at this pic plzzz........
http://s58.photobucket.com/albums/g2...gAnch=imgAnch1
cud u tell me wich temp is of which part ?????
__________
and plzzz tell me a gud software to monitor temp and also one for checkin for artifacts........ati toolwasnt working..i dunno y......
Last edited by anilthomas26; 08-09-2006 at 10:10 AM. Reason: Automerged Doublepost
Old 08-09-2006, 11:17 AM   #23 (permalink)
dOm1naTOr's Avatar
Your cab's rear fan grill has to be that big to even fit the 120mm fan. Not all ordinary cab's has this features.
Also the temp 1 is of CPU nd temp 2 if of mobo chipset. But there is somethin wrong with the temp3[shown as 128c]. See its mine:
Attach one or two fans like this. This could make your card oc much stable.
G3: XPS M1530 |
FZ 16.
Old 08-09-2006, 01:21 PM   #24 (permalink)
when i overclock to 432/1150 ati tool detects artifacts........
and ma gpu temp jst after playin games like "chronicles of riddick" comes to around 70-72.......
so...the artifactes are due to the temp ????
adding the fans will reduce the artifacts ?????
i'd really like to get the full potential of my card.....
__________
wat does the core temp indicat...the one at 56.....????
__________
and i am gonna fix maybe 2 fans like u have done...and one more for takin hot air out.......
i am just concerned bout the noise its gonna make....
__________
sry....but one more thing.......
the artifacts begin to appear at bout 70........
and wud i require any other type of coolin solution...????
and how much wud they cost ?????
can fixin 2 or 3 fans help in maintaining a temp below 70 ?????
__________
now bout fixin the fan..........
can i fix two fans taking power from the same 12v rail ??????
or maybe 3 ????
Last edited by anilthomas26; 08-09-2006 at 01:21 PM. Reason: Automerged Doublepost
Old 08-09-2006, 01:34 PM   #25 (permalink)
dOm1naTOr's Avatar
Ya..my GPU temp after playing any heavy games for more than 2hrs is max at 55~60. Ive attached a total of 6 additional 80mm fans. Take a look at the blow fans.
Bout the FANSPEED indications, i dun get any indications like the core temp nd the temp1 seems to be same as the CPU temp displayed in ASUS utility.
Ya u can attach some 3 fans taking power from the molex connectors[even single connector as SMPS will nullify the load nd will give power according to the need of each connector as far as the PSU can hold.]
G3: XPS M1530 |
FZ 16.
Old 08-09-2006, 06:53 PM   #26 (permalink)
ok.....here is data from fanspeed bfore fixing the fans :
http://s58.photobucket.com/albums/g2...gAnch=imgAnch2
now....after i fixed 4 extra fans :
gud enough...huh ???
i havent tried playin any games.......be right back........
__________
at 420/1160........ati tool detects artifacts at bout 70C.........
and here is the temp jst after running ati tool....
the ambient temp when i switched on my comp was 41....
now it rose to 48.....
the core temp is still around 56 ....
and btw.....wat is ambient temp ????
__________
i played for bout 15 mins....here is the log from riva tuner.......
the core temp goes upto bout 79 !!!!!!
havent noticed any artifacts though.......i think once.......
wat do i do......i havent overclocked much yet........
Last edited by anilthomas26; 08-09-2006 at 06:54 PM. Reason: Automerged Doublepost
Old 09-09-2006, 09:07 PM   #27 (permalink)
plz help me guys......
Old 09-09-2006, 09:55 PM   #28 (permalink)
dOm1naTOr's Avatar
your temp sensor in card may not be showing the correct temp. DO like this. Play some heavy games till u think that it has reached high temp then suddenly pull the plug[ya it would sometimes lead to some file corruption but to solve such problems these r necessary]. the plug nd see touching the top side of the card where GPU is situated below nd [make sure ur grounded or simply touch the floor with ur foot] see if its really that hot or the sensor simply says 83or 84.
G3: XPS M1530 |
FZ 16.
Old 10-09-2006, 12:28 AM   #29 (permalink)
try some setup like this ..
the 6600GT came down from 95c under load to 80c under load ... if this is so for a 6600GT then this can work for u too .. specially if u open up the flap over the HSF combo ...
Old 10-09-2006, 01:28 AM   #30 (permalink)
dOm1naTOr's Avatar
@DEATHVIRUS..
the picture is vague..Have u attached 2 normal 80mmfans?Nd how?
Is it like this?
It would be more effective if he attaches one more fan inclined like this nd another fan behind the cab for exhaust like this:
and
I think thes the limit for air cooling[four 80mm fans for gcard]. If the prob isn't yet solved u must try some water cooling etc. Again i doubt that ur temp sensor is workin correctly or not??
Always remember: More fans-more dust. So u must clean the heatsink nd fan of the gcard once in a while as dust will hold up quickly as that much air is thrown into it. More dust could rise the temp nd even damage the card.
with all this cooling my card is running at at oobercooled 41c at idle nd a max of 50c. and CPU at idle 36c nd at full load 54c. But my PC sounds like a generator..
G3: XPS M1530 |
FZ 16.
