Old 04-09-2006, 06:40 PM   #1 (permalink)
crazywolf
Posts: n/a
Question please help urgent
Iam going to asemble a new computer. and i dont know much about it. my budget is 40k. and i prefer pentium duo processor with an average performance . anybody who knows much about it please help me.
Old 04-09-2006, 06:57 PM   #2 (permalink)
samrulez's Avatar
Default Re: please help urgent
Core 2 Duo E6300.........10.5k
mobo....no idea!.........6k
2GB/1GB.....DDR2.....10000
XFX 7600GT..........13k
****************OR******************
AMD Athlon 3800+X2.........10,000
ASUS A8N-VM CSM/A8N-E..........4500/5500
1GBX2 DDR400 MHz....................8000
XFX 7600GT.........................13k.
etc etc..........
Sam :D Rulez :lol:
samrulez is offline
Old 04-09-2006, 07:13 PM   #3 (permalink)
dOm1naTOr's Avatar
I would say :
AMD Athlon X2 4200+.........11k
ASUS A8NE..........5500
2x512 DDR good one........5500
XFX 7600GT..........11000
I would recoment AMD 4200+ over E6300 as My 4200+@2.6 beats ene E6400 with ease. And ASUS A8NE is really ..really a very nice board..beast in features, stability, perfomance nd overclocking nd package contends...all this in 5.5k
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 04-09-2006, 10:36 PM   #4 (permalink)
i would say get an Intel Core2Duo E6300.
12345 is offline
Old 04-09-2006, 11:36 PM   #5 (permalink)
samrulez's Avatar
@aravind_n20: R u sure 42006X2 @ 2.6 GHz beats 6400 ??? links>??
Sam :D Rulez :lol:
samrulez is offline
Old 05-09-2006, 01:06 AM   #6 (permalink)
dOm1naTOr's Avatar
4200+0c can do in most benchmarks. The only downside is DDR1 comapared to Intel's DDR800MHZ. If u use good DDR at 2-3-3-5 or soethin nd oc it upto sat 460 or higher AMD could do better.
But 4200 is much cheaper tha an 6400 nd the mobo is also much cheaper nd u can even get a good SLI mobo for AMD for as low as 6.5k.
see the screenshot nd see the perfomance is so near the core 2 extreme 6800.
Will shoot up my CPU to 2.7 or higher nd will post more screenshots.
G3: XPS M1530 |
FZ 16.
Old 05-09-2006, 05:33 AM   #7 (permalink)
TechTin.com
ravi_9793's Avatar
n here is sm more tips..
speaker0creative 5.1 SBS?(rs 2600)
mouse+keyboard-logitech(rs 650)
hard disk-250 gb,seagate Sata II(rs 4100)
ravi_9793 is offline
Old 05-09-2006, 09:22 AM   #8 (permalink)
AFAIK Core 2 Duo should be 400-800MHz or more ahead of AMD.
ie. If X2 4200 is clocked at 2.6, it may just be a rival to E6400 at best.
Anyway, E6400 is overclockable as well, and once you overclock it, AMD can't win.
I am assuming that you are not look for a gaming solution.
E6400 - 10500, for overclocking
else E6300 - 9000
MSI Neo G 965 - 6500
Upgrade the mobo later
alternately get E6300 with a better mobo
2 X 512MB DDR2 667 Corsair Value select or other RAM if this is not supported
160GB SEAGATA SATA II NCQ
akshayt is offline
- by c4u
