Old 03-09-2006, 07:45 AM   #1 (permalink)
nishant_nms's Avatar
Default 6100
Does nvidia onboard graphics 6100 supports H&L.
nishant_nms is offline
Old 03-09-2006, 11:04 AM   #2 (permalink)
gxsaurav
Posts: n/a
Default Re: 6100
yes it does support
Old 03-09-2006, 11:41 AM   #3 (permalink)
samrulez's Avatar
Default Re: 6100
Yes its a cool IGP.....and guess what?? It can run ''aero''!!!
Sam :D Rulez :lol:
samrulez is offline
Old 03-09-2006, 01:01 PM   #4 (permalink)
deathvirus_me's Avatar
Default Re: 6100
6100 is basically an onboard alternative of 6200 , slightly toned down in performance ...
deathvirus_me is offline
Old 03-09-2006, 01:35 PM   #5 (permalink)
Stalker's Avatar
Default Re: 6100
yes, it does support HW T&L & SM 3.0
| C2Q Q6600 G0 | Intel DG33FB | 4 GB Corsair 6400C5G DDR2-800Mhz | XFX 8800GTX | CM Extremepower 600W | 250GB Seagate HDD | Lite-ON 1635S DVD RW | Logitech MX-518 | Zalman RS6F | APC RS 800 |
Stalker is offline
Old 03-09-2006, 02:24 PM   #6 (permalink)
dOm1naTOr's Avatar
Default Re: 6100
Ya u can find all features of the GPU 6800(except HDTV, starting from 6150) in a 6100.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
- by c4u
