Old 01-09-2006, 09:57 PM   #1 (permalink)
Default help me guys........
no cd-rom is seen in the my computer panel and also in device manager... i had alos tried by adding new hardware option , but it didnt work. wat to do??????????????
anil_861 is offline
Old 01-09-2006, 10:59 PM   #2 (permalink)
sknowonweb's Avatar
Default Re: help me guys........
Open up ur CPU . try plugging the drive to some other power and data cable .
தமிழ் வாழ்க
____________
EVIL : G00D :: YIN : YANG
________
sknowonweb is offline
Old 01-09-2006, 11:22 PM   #3 (permalink)
TechTin.com
ravi_9793's Avatar
i think ur xp has been crupted...by missing sm files.This may has happened due to improper shutdown.
try restoring the system to its best know time.
This may solve ur problem......other thing u can do is remove the drive than start the xp..than shut down..and now plug drive into the cabinet..
Now start the window...xp sud find the new device n will install it automatically.(as it is simple plug and play device).
and at last u have 2 reinstall the xp.
ravi_9793 is offline
Old 01-09-2006, 11:50 PM   #4 (permalink)
dOm1naTOr's Avatar
If it was workin earlier then its some windows problem. Otherwise check the jumper seting at the back of the drive.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 01-09-2006, 11:58 PM   #5 (permalink)
ranjikvp's Avatar
does the CDROM light come one when you restart the computer, if yes try system restore if doesn't work then follow steps mentioned by sknowonweb above, if it still does not resolve the issue replace drive
ranjikvp is offline
Old 02-09-2006, 12:18 AM   #6 (permalink)
cd-rom opens when i push the buttons,seems no problem in rom.. so tell wat 2 do
anil_861 is offline
Old 02-09-2006, 12:38 AM   #7 (permalink)
k_blues24's Avatar
Smile Re: help me guys........
First u have 2 check the cods of ur CD-ROM u have to open Cabinet unplug it and then reinstall/plug it as it is. If this not works then this may be problem of ur windows system file so u have to re-install it choose repair installation.
If this not works then check jumpers on CD-ROM ( this all informations on the pack of the CD-ROM / back of CD-ROM itself ).
tell us wat u have done ok
Talk less than u know, Show less than u have ;)
Yesterday is History. Tomorrow is Mystery.
Today is a Gift, that's why it is called as
The PRESENT.
k_blues24 is offline
Old 02-09-2006, 12:42 AM   #8 (permalink)
boss how can i reinstall xp. as cd-rom is not working...
anil_861 is offline
Old 02-09-2006, 02:14 AM   #9 (permalink)
Beware of the innocent
ilugd's Avatar
most probably loose cable connection. Can you see the cd drive in bios?
Life is too short. Have fun.
ilugd is offline
Old 02-09-2006, 10:20 AM   #10 (permalink)
ya no cd-rom was shown in bios... wat 2 do. only primary master -hard disk is seen. not other thing...
anil_861 is offline
Old 02-09-2006, 10:22 AM   #11 (permalink)
Default cd rom not workin..
also no was shown in bios set up.. only hard disk is seen.. tell me wat 2 do.. i had checked jumper , its all ok...
anil_861 is offline
Old 02-09-2006, 10:28 AM   #12 (permalink)
-The BlacKCoaT Operative-
Rollercoaster's Avatar
Default Re: cd rom not workin..
u need to chech the IDE cable and the bios option.
Rollercoaster is offline
Old 02-09-2006, 11:09 AM   #13 (permalink)
sknowonweb's Avatar
If your CD rom is undetected in Bios , change the datacable and Power cable. plug it to some other IDE slot . If it doesnt detected now , then i fear there is some serious problem in your CD rom .
If possible connect your CD Rom with some of your Friends computers or call your computer service centre .
May you Post what are the steps you take as our members suggested ,just for a clear identification to spot the solution .
தமிழ் வாழ்க
____________
________
Old 05-09-2006, 05:44 AM   #14 (permalink)
TechTin.com
ravi_9793's Avatar
if.....this problem is due to Xp ..than try reinstalling the xp.And during re-install the cd rom will work.
Try it.
This will also check wether ur xp is problem..or something else is problem.
Old 05-09-2006, 08:51 AM   #15 (permalink)
Laptoping
Sourabh's Avatar
Hey, just reset the BIOS to defaults and boot into Windows and hopefully you will see a 'New Hardware Found'.
Sourabh is offline
Old 08-09-2006, 01:43 AM   #16 (permalink)
ranjikvp's Avatar
Check how many data cables are available inside, if two, you can use the hdd cable to connect the cd-rom too and check if its getting detected in BIOS or get a new data cable and check in BIOS if the CD-ROM is getting detected
ranjikvp is offline
- by c4u
