Old 02-09-2006, 12:49 AM   #1 (permalink)
Default CPU Tripped
Hi frnds!
Today i shifted my computer to my study room which is not properly ventilated as i keep all windows closed. Although i have 1 extra fan installed in my CPU, to my surprise, the CPU was tripped due to over heating after 30-40mins of usage & i heard some strange beeps from CPU speaker b4 shutdown.
At 1st i didnt knew wat happened, so i just thought it to be some probe in my UPS, but when i kept it off for 1hr & restarted, i got bios message "CPU WAS SHUT DOWN PREVIOUSLY IN ORDER TO PREVENT OVERHEATING".
The system started this time, but didnt found any boot device, so i checked my priority in bios & restarted it. I worked, but the very next time i turned on my PC again it didnt found any boot devices neither my DVD writer. so i restarted it. then it was ok, but since then every alternate retart, i get the same error that NO BOOTABLE DEVICE FOUND & it gets solved on restarting.
ooops....... to boring to restart it again & again & a gr8 trouble 4 my mom who gets confused each time she starts PC.
wuzz wrong with my cpu? is anything serious? i have my PC in warranty.shud i contact the dealer or the probe can be solved....plz plz help guys...
Pentium 4-3.06Ghz, D102 Chipset MOBO with 256MB onboard ATI Graphics, 1GB DDR-2 transcend, dvd writer, CD RW, 80 GB HDD, merciry tv tuner, Sound Blaster 5.1, 350 watt UMAX PSU.
Intel Pentium triple3core 5.5Ghz intel original D502 GCCL Mobo 50 Gb DDR-4RajaPathar 2048Mhz 40 TBHDD EX12500XFX2GbDisplay SonyBlueRay+/-RW80.5GB
return_of_vengeance is offline
Old 02-09-2006, 10:39 AM   #2 (permalink)
-The BlacKCoaT Operative-
Rollercoaster's Avatar
Default Re: CPU Tripped
seems like ur processor cooling fan has gone bad. Replace it. and reseat the CPU too.
Rollercoaster is offline
Old 04-09-2006, 01:41 AM   #3 (permalink)
the cpu fan is working fine & probe is something else, now my processor temperature always remains around 63C, (when the cabinet is opened) some fault in aluminum sink, or thermal paste needz to be reapplied?
Old 05-09-2006, 01:17 AM   #4 (permalink)
dOm1naTOr's Avatar
If CPU is heated beyond a certain limit for long the paste becomes a black powdery substance. I think it might have lost its properties. Try reapplying it or get some good thermal paste like Artic Silver.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 06-09-2006, 02:57 AM   #5 (permalink)
@aravind
hey , i hav bought this pc just few weeks ago, can there be a probe of thermal paste?
Shud i install 1/2 more fans inside the CPU?, just now i m using it in Opened Cabinet condition...with proper ventilation...
Last edited by return_of_vengeance; 06-09-2006 at 02:59 AM. Reason: Automerged Doublepost
Old 06-09-2006, 01:26 PM   #6 (permalink)
dOm1naTOr's Avatar
I think the CPU voltage in BIOS has somehow turned high. Its its so the CPU gets heated up quickly.
I dun know the voltage of an Intel procy. It might be on the CPU box cover. See if its beyond the limit.
G3: XPS M1530 |
FZ 16.
Old 06-09-2006, 01:34 PM   #7 (permalink)
i guess u doboth of this...change the hestsink fan of cpu...or apply as5 on the fan...........
if its still doesnt help.....thanits a power supply problem..may b itgot sorted and have done internal damage while transport....
but most probably its the heat sink fan problem........my frnd faced sameproblem..called hardware enginer..he replaced the fan..u get a new one for 100-150buks....
magnet is offline
Old 06-09-2006, 11:26 PM   #8 (permalink)
ok guys i will change the CPU Fan & let u know tommorow.
Thnx 4 ur help.
- by c4u
