Old 01-09-2006, 07:24 PM   #1 (permalink)
Question award bios upgrade????
somebody Please tell me how can i get Latest Free Award BIOS Version Upgrade.
I Have run BIOS Agent & i got Fallowing Information.
BIOS Date: 05/21/01
BIOS Type: Award Modular BIOS v6.00PG
BIOS ID: 05/21/2001-i810-ITE8712-6A69ME1CC
OEM Sign-On: P6IWP-FE Ver 2.0 05/21/2001 2M
Chipset: Intel Whitney 82810E rev 3
Superio: ITE 8712F rev 4 found at port 2Eh
OS: WinXP SP2
CPU: Pentium III 866 Mhz
BIOS ROM In Socket: Yes
BIOS ROM Size: 256K
Memory Installed: 192 MB
Memory Maximum: Unknown
Memory Slot 01: 128 MB
Memory Slot 02: 64 MB
i also visited http://www.esupport.com/biosupgrades/ this site but its not for free.
Thanx...
vivekrm007 is offline
Old 01-09-2006, 08:37 PM   #2 (permalink)
Stalker's Avatar
Default Re: award bios upgrade????
try @bios agent
refer this link http://www.esupport.com/biosupgrades/
| C2Q Q6600 G0 | Intel DG33FB | 4 GB Corsair 6400C5G DDR2-800Mhz | XFX 8800GTX | CM Extremepower 600W | 250GB Seagate HDD | Lite-ON 1635S DVD RW | Logitech MX-518 | Zalman RS6F | APC RS 800 |
Stalker is offline
Old 02-09-2006, 11:24 PM   #3 (permalink)
you can check in ur motherboard cd where u may find bios magic, bios utility , somway titile software that can update ur bios..
vick_zone is offline
- by c4u
