Old 31-08-2006, 06:24 PM   #1 (permalink)
Exclamation upgrade
hi everyone
i have 8x agp card, intel 865 mother board, p4 2.4 and SATA 80GB HDD.
the board is giving some problems so i wanna change the board. can u suggest a board that will support my existing CPU and AGP card and SATA HDD
if i have to upgrade and keep the same AGP card can u suggest a new board and CPU combination in 12k.
if i have to upgrade and keep the same CPU can u suggest a new board and graphics card combination in 10k
amps is offline
Old 31-08-2006, 06:42 PM   #2 (permalink)
Stalker's Avatar
Default Re: upgrade
u have not mentioned ur processor's socket! is it lga775??
915 + p4 2.66 (with HT & EM64T)............less than 10k
| C2Q Q6600 G0 | Intel DG33FB | 4 GB Corsair 6400C5G DDR2-800Mhz | XFX 8800GTX | CM Extremepower 600W | 250GB Seagate HDD | Lite-ON 1635S DVD RW | Logitech MX-518 | Zalman RS6F | APC RS 800 |
Stalker is offline
Old 31-08-2006, 07:25 PM   #3 (permalink)
sysrq's Avatar
Default Re: upgrade
if u dont have a ok agp card like 6600gt/6800/6800gt/.. then it is preferable to change ur gfx card+mobo+cpu , otherwise just go and change ur mobo and save money.
sysrq is offline
Old 31-08-2006, 08:10 PM   #4 (permalink)
Manchester United
abhijit_reddevil's Avatar
Default Re: upgrade
Intel 865 supports only socket 478 processors.
PS3-Ipod Touch 4G-Samsung Galaxy Ace-Sapphire HD 6870 Twin Frozer-Creative Zen:cloud9:
abhijit_reddevil is offline
Old 31-08-2006, 08:49 PM   #5 (permalink)
Stalker's Avatar
Default Re: upgrade
@digitized
nah...........some 865's support lga-775 & dual-cores
check this thread out:
intel 865 v/s 845
scroll down to find the links to these mobos
Stalker is offline
- by c4u
