Old 31-08-2006, 03:35 PM   #1 (permalink)
Unhappy Boot Problem
I have a Celeron Processor, Samsung Hard Drive, Intel D845GVSR MotherBoard.My Problem is that whenever I boot my computer tells me that there is no hard disk connected.I went into BIOS and found that there was no Prmary IDE. What Should I Do????Pls HELP.
Brainstormer is offline
Old 31-08-2006, 04:57 PM   #2 (permalink)
Default Re: Boot Problem
check the connections for ur hard disk , the two cables one frm mobo and other from power supply , the red line in both the cables should be facing inwards towards each other, also check the jumper settings
are u tryin to connect other hard disk??
signature??? :???: Let Me Think About It!!!:-D
paul_007 is offline
- by c4u
