Old 31-08-2006, 12:44 PM   #1 (permalink)
Default Suggest Good 17” LCD Moniter with DVI Input
Hello Friends,
I want to buy 17” LCD Moniter with DVI Input, I have following models in mind
View Sonic VP720b @ 12,600/- at Lamington Road
Samsung SyncMaster 740B @ ?
Which is good one? Is there any other good model?
I have not used any 17” LCD monitor b4, Is there any disadvantage of 5:4 aspect, as I am only familiar with regular 4:3 CRT aspect
Please share your experience if any one has used this b4.
I Have mobo ASUS with GeForce 6150 onboard graphics & DVI output
sachin46 is offline
Old 31-08-2006, 02:17 PM   #2 (permalink)
Default Re: Suggest Good 17” LCD Moniter with DVI Input
The Viewsonic VP720b is far better than other LCD's. I have one and I can vouch for it. It uses a 8-bit panel as opposed to 6-bits used by most other LCD's. At 12.6k, it may be a 1000 bucks more than other 17" LCD's, but it's worth it. You won't have any problems with the 5:4 aspect ratio.
drvarunmehta is offline
Old 31-08-2006, 11:30 PM   #3 (permalink)
Smile Re: Suggest Good 17” LCD Moniter with DVI Input
I am also thinking to finalize on Viewsonic VP720b, but I don’t have taste of any LCD, therefore it is beter to have some feedback b4 investing.
Can you pl. tell me more on following points?
- What happen when you change the resolution from native, like in gaming…… as I don’t have separate graphics card (which you have), therefore I have to run the games in low resolution like 800×600 from native 1280x1024. then how the quality differs ?
- Is these LCDs are really reducing the eyestrain, when we spend more time on PC?
- Is there are any 17" LCDs available, which gives 4:3 aspect ratio?
sachin46 is offline
Old 31-08-2006, 11:43 PM   #4 (permalink)
I ran some games at 800x600 and they still looked good.
Yes they are.
Afraid not. All 17" LCD's have a native resolution of 1280x1024 (5:4). But you certainly won't encounter any problems running at this resolution as even onboard graphics support this comfortably.
Old 01-09-2006, 12:33 AM   #5 (permalink)
720b/920b displays are *NOT* 8bit... they use 6bit TN panels. 730b/930b had 8bit P-MVA but they are unfortunately not available in India. 720b is as bad as any other display in terms of color. It might be better in terms of sharpness as it doesn't have its Overdrive circuits driven as aggressively as the samsungs. The cheapest 8bit panel is the Viewsonic VX2025WM for around 22k. If you are ready to spend around 15.5K, then get the Viewsonic VA1912W 19" widescreen. TN panel again but atleast you get widescreen.
Here's the link:
http://prad.de/en/guide/screen3061.html
C2D E8400@3.8, P5N32-E SLI, 2GB Cellshock DDR2 1000(4-4-4), 8800 Ultra SLI, 2.7TB storage, CM Stacker 830, TT 1200W, Dell 2005FPW, Lots of Audio HW.
Ch@0s is offline
Old 01-09-2006, 01:13 AM   #6 (permalink)
Maybe I was mistaken. I got the info from newegg.com which isn't always reliable.
Anyways the true 8 bit panels are quite a bit more expensive and not worth it unless you use them for Photoshop or other applications where colour reproduction needs to be perfect.
If you have to choose between the Samsung 740B and Viewsonic VP720b, get the Viewsonic.
Old 01-09-2006, 01:24 AM   #7 (permalink)
Yup... The 730b was available initially for around 20k but I guess they stopped it cos of lack of demand in india. Out of those two, the viewsonic is a better deal easily though I'd instead look at widescreen options. 8bit panels are not necessarily for just photoshop. Even for mundane everyday tasks, movies, gaming, an 8bit panel makes a substantial difference in image quality... Things just look fantastic on my S-IPS panel 2005 compared to my Dell XPS laptop display which is TN.
Ch@0s is offline
Old 01-09-2006, 01:54 PM   #8 (permalink)
Yes they are.
Now I think I should go for Viewsonic VP720b, as it is in my budget also, a week before pries is 13.5K- & now 12.6K great!!!!!
Also Now you have cleared my most of the doubts, bcoz I herd from some one that LCDs are look bad @ other than there native resolution, also I have onboard graphics therefore I am is some doubt……to take 17” CRT or 17” LCD
Mainly I work on software’s but some time like to play Game & watch movies.
Pl. tell me one more thing, is this monitor have pivoting function to switch to Portrait mode for working vertically…..
__________
widescreen or VX series are currently not in my budget………. but I will try to get 8 bit rather than above 6 bit by extending my budget , ……….. Lets seeeeeee.
but now ...... is this Viewsonic VP720b is best buy @ 12.6k ???
sachin46 is offline
Old 01-09-2006, 01:59 PM   #9 (permalink)
Yes it does.
Yes. Other monitors in this price range are general purpose ones. The VP720b is from the Viewsonic Professional series, so you can expect it to be better than regular Samsung, LG, Acer monitors.
Old 02-09-2006, 10:45 AM   #10 (permalink)
Yes it does.
Thanks for the Info & your useful comments,
Finally I am going for Viewsonic VP720b
sachin46 is offline
Old 02-09-2006, 11:11 AM   #11 (permalink)
aquamatrix's Avatar
BenQ Fp741e+ it'll cost you 11.5k. it's good even got built in speakers with it.
aquamatrix is offline
Old 02-09-2006, 11:21 AM   #12 (permalink)
 Macboy
goobimama's Avatar
Seriously? Speakers? On the LCD? I'm yet to find some decent speakers built into the monitor, otherwise, they are mostly a waste of space (the monitor could have been slimmer).
I'm like a bird... :)
goobimama is offline
Old 02-09-2006, 11:49 AM   #13 (permalink)
yogi7272's Avatar
do let us know ur experience with it ...
yogi7272 is offline
Old 02-09-2006, 05:13 PM   #14 (permalink)
So does the VP720b.
Old 03-09-2006, 10:40 AM   #15 (permalink)
AmbarD
Posts: n/a
hey guys
im not making new thread but asking the same question
mesa want monitor 17"lcd for max 13k
i can only buy online from itdepot etc etc
plz suggest some good monitor
thnaks guys
remember im gonna buy online
__________
hellooooooo
Old 03-09-2006, 11:15 AM   #16 (permalink)
Why do you only want to buy online? It just limits your choices.
If you must buy online then tell us which models are available online so we can choose the best one.
Old 03-09-2006, 05:01 PM   #17 (permalink)
AmbarD
Posts: n/a
errrrrr......
i thought i asked you guys the question
also i need to buy online as im in GURGAON and there are no good places where i can buy from
Old 03-09-2006, 06:31 PM   #18 (permalink)
Go to New Delhi to buy it. You are making an investment of Rs. 13,000, the least you can do is travel a bit and make sure you get your money's worth.
Go to Nehru Place and buy the same LCD sachin46 is buying, Viewsonic VP720b.
Old 03-09-2006, 06:37 PM   #19 (permalink)
AmbarD
Posts: n/a
what about Dell 1707FP 17" UltraSharp LCD
heres the link
http://www1.ap.dell.com/content/prod...=in&l=en&s=bsd
- by c4u
