Old 31-08-2006, 11:16 AM   #1 (permalink)
Default best conffiguration please........
please suggest me the configuration for rs35000
i want a dual cor processor from amd
and a good graphics card.
reply neede urgently
and also geforce 6600 vs. geforce 7300gs
ramana321388 is offline
Old 31-08-2006, 01:18 PM   #2 (permalink)
samrulez's Avatar
Default Re: best conffiguration please........
AMD 3800+X2.........9000
ASUS A8N-VM.......4500
XFX 7600GS ........7000
Transcend 1GBX2.....4000X2
Sam :D Rulez :lol:
samrulez is offline
Old 31-08-2006, 01:54 PM   #3 (permalink)
montylee's Avatar
Instead of Asus A8N-VM, go for K8NGM2-FID. It's got better reviews.
and i don't think Transcend 2GB will cost 8000. RAM is getting costlier each day
Intel Core 2 Duo E6300, Intel DG965RY, MSI 8600GT OC, WD 250GB SATA-II Harddisk, Transcend 1GB 667 Mhz DDR2 RAM, Samsung Samtron 55V, Sennheiser HD485 cans, Zebronics LAVA Cabinet, Zebronics 400W PSU
montylee is offline
Old 31-08-2006, 02:06 PM   #4 (permalink)
samrulez's Avatar
Hmmm,......last time i checked 1GB stick costed 4000 bucks......
another reason to get this machine faster
Sam :D Rulez :lol:
samrulez is offline
Old 31-08-2006, 02:09 PM   #5 (permalink)
In this budget you can't expect to get both a dual core and game, only one of the two is possible.
AMD 64 3000 AM2 + aftermarket cooling
1GB DDR2 533
M2N E or something, around 5500
Geforce 7600GT Palit - 8500
akshayt is offline
Old 06-09-2006, 11:57 PM   #6 (permalink)
urvish_acharya's Avatar
Thumbs up Re: best conffiguration please........
invest some more and check out this config....it'll rock honey
buddy here are 2 configs for u
M2N32-SLI Deluxe
AMD X2 3800+/4200+ (AM2 - DDR2 support)
E6300 10,000
P5B Deluxe 10,000
6800GT/7300GT/7600GT - X1800XT
1GB DDR2 RAM @ 800 MHz or 512MB DDR2 RAM @ 800 MHz
WD Raptor 150GB / WD 250GB SATA
550W PSU
2-3 120-80mm system fans
I suggest u opt for DDR2 platforms as DDR will be phased out in near future and then you will have same problems like u have getting RDRAM...and for DDR2 I prefer 800 MHZ RAM....it may be bit costly right now, but what you can do is opt for 512MB DDR2 right now and later upgrade to 1 GB of DDR2 @ 800 MHz.
urvish_acharya is offline
Old 07-09-2006, 01:07 AM   #7 (permalink)
dOm1naTOr's Avatar
Get the lowest dual core..ie 3800+ along with A8NE board. For graphics, get a 7300GTfor 5.5k. It performs equal to a 7600GS nd is almost 2k less expensive. If u want a gud brand like ASUS or XFX it would cost u 6k, but then also its worth it.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 07-09-2006, 05:44 PM   #8 (permalink)
M2N32-SLI Deluxe
E6300 10,000
P5B Deluxe 10,000
550W PSU
r u sure P5B Deluxe is 10k ? ... when asked it was around 15k
check this tooo
http://www.theitdepot.com/categories.asp?cat=1313
vinyas is offline
- by c4u
