I have a bluetooth dongle with CSR chip...It came with Bluesoleil soft and I installed the soft on my PC (3 GHz, 915 MB, WinXP pro) and the device worked fine. Then I upgraded my OS to SP2 and there was no need to install the Bluesoleil soft.
Recently, I connected the same device on a friend's PC(PIII-500MHz, 810eMB, WinXP-SP2) and it was detected without the need of Bluesoleil. After I had transferred a few files to n fro from the PC the Bluetooth icon dissappeared from the system tray...I removed and attatched the device again only to find that the device was not recognized. After trying many times over I installed Bluesoleil soft but still the prob was not solved. Next, I installed the latest chipset utility but the BT device ain't being recognized as yet.
I need to know if this is a prob with my BT dongle or the USB port of the PC. I don't have access to any other PC(not even mine) because I am in another city....
If there's a prob with my BT then which BT dongle would u people recommend me to buy...Plz tell such a brand which may b recognized by the OS without any fuss and for which I dont have to install Bluesoleil or something like that...
__________
Plz HELP me....
__________
I desperately need to sort this out...ANYBODY PLZ HELP!!!
