Old 30-08-2006, 12:29 PM   #1 (permalink)
Siriusblack's Avatar
Default MotherBoard Suggestions
hey guys i'm buying a new pc with an budget of 25k out of which i have kept 5k for mobo . Kindly suggest the most compatible mobos for AMD 3000+ 939 pin (Venice) and Pentium 4 2.66 ghz dual core........ Hurry guys i have to go to the shopkeeper on 1 sep to tell my final config
__________
Also tell which combo wld be better Amd with its mobo or P-4 one
Siriusblack is offline
Old 30-08-2006, 01:05 PM   #2 (permalink)
k_blues24's Avatar
Default Re: MotherBoard Suggestions
Why should u not go for AMD AM2 it's latest. MB For it is --
ASRock AM2V890-VSTA
features:
AM2 socket, DDRII support ( 8GB), FSB 1000Mhz, SATAII, 8 USB,
Northbridge- VIA K8T890, 7.1 channel high definition sound onboard,
PCIe x 16 slot, 10/100 Ethernet, 3 PCI slots
last but not the least
PRICE: 3900 Rs.
choice is urs
__________
OK here is the socket 939 solution :
MB : Biostar TForce 610-939
features :
AMD 939 socket, Nvidia NForce 410 Chipset with GeForce 6100 IGP ( windows vista ready but if possible ask for onboard GeForce 6150 IGP MB ), DDR 400 (4 GB max), 6 channel audio, etc....
PRICE : 3980 RS.
graphics card ( optional) : Forsa 7600FS PRICE 6800 RS.
ALL RS r apx.
pls extend ur bugget for the best one, best buy
tell me also wat u buy ok
bye
Talk less than u know, Show less than u have ;)
Yesterday is History. Tomorrow is Mystery.
Today is a Gift, that's why it is called as
The PRESENT.
k_blues24 is offline
Old 30-08-2006, 01:16 PM   #3 (permalink)
Welcome To The Jungle
sysfilez's Avatar
asus a8n-e for amd cpu, asrock has a bad customer support.
Me n My Canon EOS 350D with EF 50mm f1.8
sysfilez is offline
- by c4u
