Old 29-08-2006, 05:09 PM   #1 (permalink)
Exclamation Wireless PCI for Laptop
Hi,
I've got an Acer 2424NWXC laptop.Which came without wifi.
I want to know if i can add a wireless Mini Wireless PCI card in the slot that is on the bottom.
Will it work?
Has anyone used this or done this before
I seen this card on ebay.Pls check it out and tell me, the link is :
http://cgi.ebay.com/Intel-Pro-Wirele...ayphotohosting
elroydsylva is offline
Old 29-08-2006, 06:43 PM   #2 (permalink)
varkey's Avatar
Default Re: Wireless PCI for Laptop
u can get a pcmcia wireless adapter
Intel Core 2 Duo E6300 @ 1.86 GHz | Intel DG965WH | 2x1GB DDR2 667 MHz Transcend | Seagate 320 GB SATA II | Sony DW-Q120A | Samsung 940bw 19" LCD
varkey is offline
Old 30-08-2006, 12:56 AM   #3 (permalink)
-The BlacKCoaT Operative-
Rollercoaster's Avatar
yes it will work provided u have a mini PCI slot vacant.
otherwise u can use a PCMCIA card.. this will be cheaper and u can remove it to better battery life. wifi uses a lot of power.
Rollercoaster is offline
Old 30-08-2006, 09:08 AM   #4 (permalink)
Hi Guys,
Yes i have a mini PCI slot that is vacant.
I opened the back of the NB to check.
- by c4u
