Old 29-08-2006, 06:51 AM   #1 (permalink)
WOW... are you?
gsoul2soul's Avatar
Exclamation Network Adap. Freezes Start menu!!!
HELP !!!
My computer starts... perfectly !!!
It shutdowns... fast !!!
All in all... it's runing (loading smoooothly)
****************** BUT *********************
BUT in the begining, when you click on Start menu and ''connect to'' (so you can use internet)... it FREEZES the START menu and all
I mean... literally for 3 or 5 mins.
Why? when i had modem, it never happened !!!
but after that intial freezing thing... everything is okay... internet works fine.. and all!!!
Help!!!
Gsoul2soul
PS: by the way... mu Avast Antivirus also takes like... sometime to load... i mean usually it won't, now a days it does!!!
gsoul2soul is offline
Old 29-08-2006, 08:11 AM   #2 (permalink)
a_g = JPKN
s18000rpm's Avatar
Default Re: Network Adap. Freezes Start menu!!!
The CULPRIT maybe AVAST AV.
try installing any other AV like AVG Free (just to experiment). & then disable AVAST from "msconfig".
now restart ur PC to let the changes take effect.
NOW check whether there's any Improvement or NOT.
ASUS K53SV SX520D + BF3
s18000rpm is online now
Old 29-08-2006, 03:48 PM   #3 (permalink)
Try reinstalling your antivirus this could be the problem for sure.. i alternatively faced it recently
speedrider - The ultimate
speedrider_100 is offline
- by c4u
