Old 29-08-2006, 12:09 AM   #1 (permalink)
dhawald's Avatar
Angry sound and network problem
sometimes my dialup suddenly stops transfer
and i cannot hear the disconnect alert because
when clicking volume control, a message window appears "There
are no active mixer devices available. To install mixer devices, go to Control Panel
click Printers and other Hardware (sic) and the click Add Hardware
the same error appears when I start winamp and i cannot hear anything
I do not know out of these two problems which one is the cause and which one is its effect,they happen at the same time.
restarting solves the problem temperorily.
I have tried re installing the sound drivers but it dosent work.
I am using win Xp sp2
intel motherboard 845gebv2
dhawald is offline
Old 29-08-2006, 09:40 PM   #2 (permalink)
Stalker's Avatar
Default Re: sound and network problem
This can happen if windows Audio is disabled...
Go to Start --> Run, and type in services.msc.
A window will pop up with a list of services. Scroll down to Windows Audio. Right-click and click on Properties.
Make sure that "Startup type" is set to automatic. Also, make sure, under "Service status," start is selected.
If this does not work, try re-installing XP...............tat should solve ur problem
| C2Q Q6600 G0 | Intel DG33FB | 4 GB Corsair 6400C5G DDR2-800Mhz | XFX 8800GTX | CM Extremepower 600W | 250GB Seagate HDD | Lite-ON 1635S DVD RW | Logitech MX-518 | Zalman RS6F | APC RS 800 |
Stalker is offline
Old 29-08-2006, 11:12 PM   #3 (permalink)
dhawald's Avatar
the settings u told are already there
this problem only occurs after I connect to the net.
other wise for the whole day there is no problem with the sound anytime.
dhawald is offline
Old 29-08-2006, 11:28 PM   #4 (permalink)
Stalker's Avatar
maybe somethings wrong with ur modem drivers.........(just guessing)
usually this problem is caused due to Windows audio being disabled
Stalker is offline
- by c4u
