Old 28-08-2006, 04:19 PM   #1 (permalink)
MVP Awardee 07
uzair's Avatar
Exclamation USB or useless B
Recently i purchased this optical mouse(lg) with a usb pin.... the problem is win 98 doesn't detect it..... so i was thinking about getting a usb to ps/2 connector....
will it get detected then????
No driver cd was bundled with the mouse... must be a plug and play one...
Probability of me getting a ps3=0
Probability of me getting crazy about ps3=1
uzair is offline
Old 28-08-2006, 06:39 PM   #2 (permalink)
Default Re: USB or useless B
Check if the product website provides any drivers downloads for Win98.
patkim is offline
Old 28-08-2006, 06:47 PM   #3 (permalink)
adit_sen's Avatar
Windows 98 didnt have much native support for USB. You'll have to look for specific drivers.
AMD 4400+ X2; Compaq Presario M2202TU; Dell Inspirion 500m; Windows Vista Ultimate
adit_sen is offline
Old 28-08-2006, 06:51 PM   #4 (permalink)
sariq
Posts: n/a
^or use xp
- by c4u
