Old 28-08-2006, 02:57 PM   #1 (permalink)
Default Nokia 3230
Hi
Im new to this forum, can any body help in troubleshooting Nokia 3230. I have cleaned Circuit board with Isopropellent disconnecting all accessories like keypad, camera and LCD. will it damage any components.
Thankyou,
Ravi
Ravi.bvrm is offline
Old 28-08-2006, 02:59 PM   #2 (permalink)
Anand_RF's Avatar
Default Re: Nokia 3230
well if you have cleaned already then you should know by now if it's damaged or not.
Posted in wrong section.
Exactly what's the problem with your phone?
Anand_RF is offline
Old 28-08-2006, 03:15 PM   #3 (permalink)
Hi Anand
After power ON Nothing is displayed on LCD( working like light) afte one minute it's getting power OFF.
Thankyou
Ravi.
Old 28-08-2006, 05:17 PM   #4 (permalink)
u can go to nokia service center, to find out whether it is a hardware or software problem..
signature??? :???: Let Me Think About It!!!:-D
paul_007 is offline
Old 28-08-2006, 05:54 PM   #5 (permalink)
sariq
Posts: n/a
who gave you the idea of cleaning it? phone's circuit board does not need cleaning. try keeping circuit board 1 day in sunlight - thats all you can do yourself.
if you still want then use vaccum cleaner/ blower - this is tip for other members
Old 31-08-2006, 02:07 PM   #6 (permalink)
Hi,
This is Ravi, I have got Nokia 3230, which fell into water long back and began to work after a couple of day's that's fine but recently some key's on keypad failed to work so dismandled I changed the inner keypad. when I was changing I found some grease material and rust here and there on the circuit board so I cleaned entire circuit board with Isopropellent and assembled it after drying.
Now when I switch ON Blank screen(failed to boot) is displayed and switch's OFF automatically after some seconds. can you give me any suggestion to repair my mobile.
Thankyou,
Ravi.
- by c4u
