Old 28-08-2006, 08:18 AM   #1 (permalink)
Default E6400 or x2 4600 am2 ?
which is better ?
vinyas is offline
Old 28-08-2006, 08:41 AM   #2 (permalink)
dOm1naTOr's Avatar
Default Re: E6400 or x2 4600 am2 ?
I think E6400 is better, but its much expensive than the AMD and a good mobo for it is also much expensive at more than 10k!!But u can get. Get a 4800+ am2 instead.
__________
It has got 1x2 mb cache.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 28-08-2006, 09:31 AM   #3 (permalink)
yes E6400 is much better , but costly , go for it if u can afford it...
signature??? :???: Let Me Think About It!!!:-D
paul_007 is offline
Old 28-08-2006, 12:13 PM   #4 (permalink)
deathvirus_me's Avatar
If u plan to use at stock .. definitely the X2 4600+ .... the price is quite less .. but if u do plan too OC ,.. get the E6400 ..
deathvirus_me is offline
Old 28-08-2006, 01:58 PM   #5 (permalink)
I would ge E6300 even over X2 5000.
OC the 6300 and it beats or almost equals FX62 overclocked
At stock E6300 should perform similar to a 4600, +- something
akshayt is offline
- by c4u
