27-08-2006, 05:51 PM
Is 3000+ hotter than 4200+ ?
One of my friend bought an AMD 3000+ venice along with ASUS A8N VM board and Simtronics mem 2x256 @ 2-3-2-6(wow!).
First without OCing his normal temp was 34~36 when idle and max upto 40~41 when at load. I persuaded him to overclock nd he achieved 2.3 from 1.8 nd he was shocked with the temp like 54~56!!!. So I set it back at 1.8 but the problem is that now his idle/load temp has raised much to 38~40/48~52!!!!.
Now even wothout ocing the temp is high nd he is blaming me for this. What should I do??
Now my new X2 4200+ has idle temp of 36~37 nd 46~47 at full load. Even after ocing from 2.2 to 2.6 its safe at 51max at full load(both core at full load by CPU tester pro). My temp will be normal if I set the stock speed.
PLZ help me to solve his problem.
ALSO WHAT IS THE USUAL TEMP OF AMD 64 AT IDLE ND LOAD BEFORE AND AFTER NORMAL OCING???AND WHAT IS THE HIGHEST SAFE TEMP???
[both of us has adequate case cooling with 5x80 mm fans.
G3: XPS M1530 |
FZ 16.
27-08-2006, 07:12 PM
Re: Is 3000+ hoter than 4200+ ?
restore back all settings including voltages
27-08-2006, 07:30 PM
Tried everything by reseting the bios nd tried seting default values.
G3: XPS M1530 |
FZ 16.
27-08-2006, 07:52 PM
is the computer setup the same.....or has he changes he desk or the position of his table/desk?.
Sam :D Rulez :lol:
27-08-2006, 08:04 PM
@ aravind_n20
my cpu temp varies 46-50.5 c in this cold weather.vcore 1.47V
i want to oc my mobo.can u tell me what precautions i must take.i also want to 512 mem stick 4 this.
AMD X2 260, GA M68MT-S2P, Gskill RipjawsX 4GB, 500Gb Seagate, Cooler Master eXtreme Power Plus 600W, Altec Lancing atp3, Samsung B2230 TFT, Numeric Digital 600 EX-C UPS.
27-08-2006, 09:14 PM
The CPU voltage rating is far higher than its normal. AMD 3000+ should be 1.35~1.4v max.
http://www.amdcompare.com/us-en/desk...=ADA3000DAA4BP
Yours 1.47 is higher. Usually the CPU v is increased manually when CPU is ocing, nd to supply adequate power to CPU. Yours voltage is adequate for ocing. Follow these steps:
First u should install atleast 3x80mm chassis fan extra(additional to PSU nd CPU).
Enter the bios nd set the CPU multiplier to 9(max for A8N VM) and slowly increase your CPU bus speed from 200 to max of 270. But I would recoment to set to some 250 or 260. But do it by small steps, say 5Mhz per step. Restart every time and boot into windows nd chech whether its stable nd also note the CPU temp at max load nd it shouldn't exceed 55. U can set even higher than 270 if u have good CPU heatsink/fan combo.
Check the v nd clocks using cpuz:
http://www.cpuid.com/download/cpu-z-136.zip
__________
Is there any way of lowering the CPU voltage on A8N VM????
G3: XPS M1530 |
FZ 16.
Reason: Automerged Doublepost
28-08-2006, 12:31 AM
No pain....No gain
I have an AMD64 3000+ venice on A8N-E overclocked to 2.7GHz on stock cooling with idle temp of around 38C and load of 52C.
And few days ago I backed it down to its default and the temp. came down by around 5-7C for both idle and load. Now its again back to 2.7GHz.
28-08-2006, 02:35 AM
thanks aravind_n20
i increased fsb by 5. the vcore also increases (1.456-1.480V) to (1.448-1.488V)
as frm cpuz.the vcore & core speed always varies. is it normal?
i have 256 mb(200 mhz) dynet ram(3-4-4-8 latencies),can it handle ocing?
i decreased its speed to 166 mhz for safety.
do i need to change the bios further? tell me do i need to reduce the vcore,then how?
28-08-2006, 02:49 AM
Well .. 55c is quite ok .. temps depend a lot on the ambience too .. maybe the fans got some dust on it ..
Also .. , if the temps were around 55c with the OC , then its absolutely ok ...
Also , make sure he disabled "Automatic Temp. Control" ...
And about the vcore , mine varies from 1.45-1.51 ... a little higher can keep things more stable ... upto 1.55 is quite ok ..
28-08-2006, 08:10 AM
yaa higher vcore can make it stable but cam bring up the temp.
@coolsunny
dynet rams are totally crappy. Ive 2x512 transcent and 2x256 dynet.
I would say simtronics is a very goo mem as two of my friends are running it at 2.5-3-2-6 @400MHZ in dual channel.
But my dynet can't even do 2.5-3-3-7 @400. If I unplug the dynet and use only transcent I can reach 2.7~2.8 easily but if i plug in dynet for more mem, the cpu can only do 2.4!!!!why I dun know, but even if I leave mem settings to default I can't make it higher than 2.4.
But u can try even more higher freqs. and as deathvirus_me said upto 1.5v can be considered safe and reach max clock at bout 1.5v nd see if its stable.
G3: XPS M1530 |
FZ 16.
28-08-2006, 10:16 AM
aarvind.......first i guess if u really worried abt temperature........get as5(artic silver 5) apply on your processer.........and job is done.....
and also addsome fansin your cabinet......
bt i dont thing that temperature are to worried abt...i have used 3000+ at 61'C....without oc............the only thing to worry is when temp crosses 80-85-9o mark....but nowadays bios has th option to shutdown pc as soon as it is reached...so need not worry..........jus get as5 and a decent cabinet...also if possible get everest home edition and check the temp again......
28-08-2006, 12:04 PM
Thats what .. 55c with that much ov is quite an ok temp. .. My CPU idles' at 38-42c , and at load goes upto 48-50c ... so ur temps are quite ok .. specially at a higher voltage ...
28-08-2006, 02:03 PM
was that 1.47V for northwood core?
28-08-2006, 03:07 PM
I too have got a 3000+ with A8N VM and 256x2 400MHz ZION RAM and stock cooling,with no fans installed other than the CPU fan.How can I overclock it?Do I have to use the BIOS or any other software utility?
Intel Core i3 2100 //4GB Corsair DDR3 1333 RAM //Intel DH61WW//Sony AD-7260S DVD-RW//Samsung 2033SW Monitor//Windows 7//Seagate ST3250310AS 250GB HDD
28-08-2006, 03:12 PM
read the oc guide. anyway, i don't think that mobo is made for oc and nor is any other onboard video mobo made for oc, you probably won't go high unless you change it.
28-08-2006, 03:31 PM
do i need to change the bios further? there is no options for locking pci/pci-e bus
28-08-2006, 03:32 PM
I just bought the rig a month ago!
28-08-2006, 08:34 PM
you bought the wrong rig. I keep telling people not to buy that motherboard yet they buy. sorry, but not my fault.
make sure that the pcie etc is locked, check google whether it supports the locks or not, a8n e does.
28-08-2006, 09:08 PM
#19 (permalink)
@GeekyBoy
with that board u can oc a max upto 400~450mhz. But first what u want to do is to install as much as 80mm fans in ur cab. Better use one or two intake and some 2-3 outlets.
Enter the bios nd disable cool n quite nd under "jumperfree configuration" keeping the CPU multiplier at 9x(max for VM) slowly raise the cpu bus and follow the steps mentioned above.
Now Im at 2.75 Ghz nd at idle the temp is 41~42 nd at full load it has reached 58~59 nd on running cpu tester pro for 10-15 min it almost reached 61.
Im using very elaborate air cooling but the temp seems beyond control.
G3: XPS M1530 |
FZ 16.
29-08-2006, 12:50 AM
#20 (permalink)
@ aravind_n20
how u r taking snaps of cpuz & uploading it.tell me.
29-08-2006, 01:37 PM
#21 (permalink)
Originally Posted by aravind_n20
@GeekyBoy
Since geeky boy has Zion memory......his system will crash!.....coz Zion cannot take oc more than 10MHz (atleast recommended!)....
When u increase the FSB the memory clock will also increase.....so if u take the FSB to 210MHz then the memeory clock will be @ 210MHz i.e 420MHz (DDR).....
SO first force the ram to 333MHz or 266MHz (according to the increase in the FSB)........
Then as u increase the FSB start the PC and run Prime 95 for 5mins each time..............and after 350+ - 500MHz+ run Prime 95 for 6hrs........also after u finalize the OC...
Also keep checking the memory speed through CPU-Z...at each stage...and make sure it does not go above 205MHz i.e 410MHZ (DDR)...
Sam :D Rulez :lol:
29-08-2006, 03:39 PM
#22 (permalink)
CG Artist
@aravind how have u fixed that 80mm fan below the gfx card?
29-08-2006, 07:37 PM
#23 (permalink)
Hmm .. at stock latencies (3,4,4,12!!!!!!!!) , my zion modules can go upto 240 MHz stable for 6 hrs. Prime ... But with forced latencies of 2.5,3,2,6 , it hardly manages anything over 215 MHz ...
Run CPUz ... Press Alt+PrtScr ...
30-08-2006, 01:14 AM
#24 (permalink)
@gaurav_indian
Ive not fixed them. but it just stands on four lengthy screws as seen in the pic.
In case of gamin I place it below Gcard nd for other work like HDD intense like defrags i move it to HDD side or the chipset side. Its a good way of cooling as there is a rich supply of air from front intake(cannot be seen on pic) nd the fan on screws throws the air to gcard nd which escapes through the 3 PCI vent holes on back of cab.
__________
@deathvirus_me
can u give your 3D mark scores nd some other benchs which u have/can run??I think 2x1GB makes a lot of difference.
G3: XPS M1530 |
FZ 16.
30-08-2006, 02:28 AM
#25 (permalink)
About 135xx in 3DMark03 , 62xx in 3DMark05 , 33xx in 3DMark06 ... though i never benched with the oc'ed CPU ... i should get a bit higher scores i think .. check this link out : http://www.techenclave.com/forums/ri...llery-265.html
I do remember hitting 6400+ with the card running at 510/1200 ... but hey .. 62xx isn't bad at all .. i got the running up at 540/1350 ... but i didn't dare to bench , as i don't have a good enough PSU ...
30-08-2006, 04:02 AM
#26 (permalink)
What is wrong with the A8N-VM apart from lack of oc ability? Anyway I too have Athlon64 3000+ & Asus A8N-VM combo, 1 GB RAM, onboard audio & video and my idle temp is 49C. While playing FIFA WC 2006, temp shoots up to 56C. I have 2 x antec 80 mm fan plus an additional cheap 80 mm fan. Applied Antec Silver thermal compound but there is no change in temperature and i have given up.
30-08-2006, 11:28 AM
#27 (permalink)
@ deathvirus_me
its not working?whts wrong?
30-08-2006, 12:34 PM
#28 (permalink)
Make sure the window is higlighted ...
30-08-2006, 02:07 PM
#29 (permalink)
are....
Just press Print Screen.........and then go to MS Paint and Edit---->Paste ...
Voila u have a screenshot! But of the full screen...
To take a shot of only CUP-z press Alt+Print Screen and go to paint and paste it there...
Sam :D Rulez :lol:
30-08-2006, 08:22 PM
#30 (permalink)
@samrulez
its a bit confusion...for a newbie say like this:
first click the CPUz window nd make sure its the active window nd hit alt+prnt scrn, nd go to paint nd paste it nd move the resize slider to fit the image perfectly nd save it.
G3: XPS M1530 |
FZ 16.
