Old 26-08-2006, 06:59 PM   #1 (permalink)
arcticflare's Avatar
Default Best Processor And Mobo Under 10k
Can someone suggest a gud combo of motherboard and processor for under 10k. Can be AMD or INTEL. Urgent plz..
arcticflare is offline
Old 26-08-2006, 07:03 PM   #2 (permalink)
samrulez's Avatar
Default Re: Best Processor And Mobo Under 10k
Asus A8N-VM CSM..........4.5k
Athlon64 3500+......6000
If u oc the processor to 2.4GHz.....then it will be come a 3800+ ...
Sam :D Rulez :lol:
samrulez is offline
Old 26-08-2006, 07:20 PM   #3 (permalink)
Asus A8N-E Rs. 5500
Athlon64 3200+ Rs. 4500
This mobo will give better results while overclocking compared to the A8N-VM CSM. Keep in mind that it does not have integrated graphics but in every other way its better than the A8N-VM CSM.
drvarunmehta is offline
Old 27-08-2006, 10:09 AM   #4 (permalink)
AMD 64 3200 Venice + Asus A8N E + Good after market cooling, overclock the CPU and make it as fast as a 4000 Clawhammer or faster, maybe upto FX55!
akshayt is offline
Old 27-08-2006, 11:49 AM   #5 (permalink)
isnt this good
Intel (dual core)- 820 for P4 socket 775, 2.8 GHz ,800MHz, 2MB cache
Intel D102GGc ATi integrated gfx ,16xPCX slot ,DDR2 support
this will come within 10 k (around 9.5 K)
signature??? :???: Let Me Think About It!!!:-D
paul_007 is offline
Old 27-08-2006, 12:19 PM   #6 (permalink)
Google Bot
Pathik's Avatar
sam gave the best one if he doesnt have a gfx card......
other wise a8ne + athlon 64 3200+
Pathik is offline
Old 27-08-2006, 12:29 PM   #7 (permalink)
What is the usage?
akshayt is offline
Old 27-08-2006, 12:57 PM   #8 (permalink)
I had a p42.8ht with intel 865gbf. Processor burnt out after a lot of overheating issues. Will the amd 64bit 3500 match the 2.8ht in speed and performance? What abt overheating issues with amd?
Old 27-08-2006, 01:24 PM   #9 (permalink)
Will beat it in almost anything or will be just about as good for somethings if not better.
Did you have a prescott?
AMD doesn't have heating issues but nor should any CPU barring prescott and if it has then it also means that it can take close to those temps
akshayt is offline
Old 27-08-2006, 01:33 PM   #10 (permalink)
i don't think 2.8ht comes under EE.
Old 27-08-2006, 01:34 PM   #11 (permalink)
get the AMD Anthlon64 3200+ and ASUS A8N-VM CSM motherboard.
12345 is offline
Old 27-08-2006, 01:55 PM   #12 (permalink)
samrulez's Avatar
Well.....the 3500+ will surely out perform u r old 2.8......and a 3000+ also comes in competition with da 3GHz....intel....prescott......
The prescott is too hot for india! ......well....if u get a Venice then it will not even go above 50* unless u choke it!.. .....the stock AMD cooler is gr8...for overclocking also...
Sam :D Rulez :lol:
samrulez is offline
Old 27-08-2006, 02:00 PM   #13 (permalink)
for photoshop or something like that, sometimes some 3.0Ghz>AMd 64 3500, however probably practically unnoticeable.
akshayt is offline
- by c4u
