Old 25-08-2006, 02:48 PM   #1 (permalink)
Default Connecting TV to PC
Hey I have Bought a 7600GS I wanna connect my TV to my card
I was successful in connecting it to the tv I am able to watch videos
But Problem is that I am not able to hear the sound from my TV
Instead It comes from the computer. I have connected It using a composite
cable as my tv is abit old one. I has got only 4 composite connections
AUDIO IN/OUT & VIDEO IN/OUT. So for gettin sound what i shud connect my TV
with.
I have an ASRock 775Dual 915GL MOBO
The card has come with a connector Having 5 outputs S video, Composite,
HDTV, and two more composite outputs Whose functions i dont know But one is
red coloured & the other one is green
killer is offline
Old 25-08-2006, 02:58 PM   #2 (permalink)
No pain....No gain
john_the_ultimate's Avatar
Default Re: Connecting TV to PC
To get audio connect the audio out from ur mobo/soundcard to the audio in (RCA "red" and "white" connector) of ur TV. The gfx card's TV-out only has video signal.
john_the_ultimate is offline
Old 25-08-2006, 03:07 PM   #3 (permalink)
How do i connect? Do i need stereo-jack-to-RCA adapter
killer is offline
Old 26-08-2006, 01:03 AM   #4 (permalink)
No pain....No gain
That's right.......u need an adapter. This is the kind of cable u must get : http://www.vertexdistributing.com/br...ale-Cable.html
Old 26-08-2006, 08:17 AM   #5 (permalink)
CONFUSED??
Do graphics card come with Audio OUTPUT??
Cause some are sayin that the red out from gfx card is audio out & green one is stereo out
And as my tv is old it has got only one audio in I think so its mono
killer is offline
Old 26-08-2006, 09:52 AM   #6 (permalink)
gxsaurav
Posts: n/a
graphics cards do not come with audio output
newer HDCP complient can pass-through audio through them though, but thats different
Old 26-08-2006, 03:15 PM   #7 (permalink)
No pain....No gain
Why get confused? See, to connect ur pc to TV for viewing movies u need two seperate cable for audio and video.
*****The video cable will connect the tv-out of ur gfx to video-in of ur TV(yellow color).
*****The audio cable (the one stated above) will connect to the front speaker output (green color) of ur soundcard/onboard audio to the audio in (red and white color) of ur TV.
Old 27-08-2006, 10:32 AM   #8 (permalink)
Alright The Solution Which U have given is just fine
But i am eager to know what are those green & red outputs on my graphics card [7600GS] used for
killer is offline
Old 27-08-2006, 10:53 AM   #9 (permalink)
sorry to disturb your thread,killer.but can i connect a tv to my 6200TC?
koolkapoor is offline
Old 27-08-2006, 03:48 PM   #10 (permalink)
No pain....No gain
If u have an tv-out option, then yes.
Old 27-08-2006, 03:56 PM   #11 (permalink)
No pain....No gain
@killer
See if this is the connectors then it is called component connector.
For more details on component video see this: http://en.wikipedia.org/wiki/Component_video
Old 30-08-2006, 11:27 AM   #12 (permalink)
Originally Posted by john_the_ultimate
@killer
Thanx Ultimate
killer is offline
- by c4u
