Old 24-08-2006, 12:21 PM   #1 (permalink)
urvish_acharya's Avatar
Red face RD RAM issue
my pc config is:-
intel 850 GB motherboard,
p 4 1.6 GHz processor
256 RD RAM(2 slots of 128 MB) and 2 are dummy..
i want to upgrade my RAM...can anyone tell me RDRAM is available in market??
i inquired in pune and ahmedabad...they says it is no more available in market??
any help???
urvish_acharya is offline
Old 24-08-2006, 12:41 PM   #2 (permalink)
Default Re: RD RAM issue
it would be waste to get RDram now bump that mobo and cpu and get a Sempron64 or amd64
Sand man is offline
Old 24-08-2006, 01:57 PM   #3 (permalink)
You won't find RDRAM anymore.
1)You need a complete system upgrade.
2)Look for second hand RAM if you still want it.
3)You may end up spending more than what it takes to upgrade the CPU+MB+RAM.
Sell your current stuff and you could get better stuff for as little as 3-4k investment, though 5-6k+ is recommended.
akshayt is offline
Old 24-08-2006, 06:51 PM   #4 (permalink)
I have RD RAM from my old PC. I can give you 2 sticks of 64 MB each. You can PM me if you are interested in buying it.
drvarunmehta is offline
Old 24-08-2006, 11:16 PM   #5 (permalink)
Stalker's Avatar
well, rd ram is not avaliable now......try to upgrade ur system & get ddr2 instead.
btw....what is the bus speed of rd-ram?? i have read tat its damn fast.
why did it get outdated then ??
| C2Q Q6600 G0 | Intel DG33FB | 4 GB Corsair 6400C5G DDR2-800Mhz | XFX 8800GTX | CM Extremepower 600W | 250GB Seagate HDD | Lite-ON 1635S DVD RW | Logitech MX-518 | Zalman RS6F | APC RS 800 |
Stalker is offline
Old 25-08-2006, 02:13 PM   #6 (permalink)
Sell your CPU+MB+RAM and get:
AMD 64 3000+ Venice
Foxconn nforce 4 with onboard video
2 X 256MB DDR 400
All this should cost around 9k and after selling your previous stuff you should be able to reduce maybe 1-2k.
akshayt is offline
- by c4u
