Re: how to increase SHARED MEMORY
For Intel M/B. (915G,910gl...)
may differ for other brands of m/b
RE-ALLOCATE/resize the OnBoard Gfx RAM.
You can do this by going to BIOS->Advanced->Video Memory->Press Enter on selection screen(u'll see some nos. like 1/0/31/32).
In the sub-screen you'll have lot of choices(e.g-8/0/120/128, 8/0/56/64) in the following manner=="Pre Allocated/Fixed/DVMT/Total Video Memory".
It works like this-- Pre allocated+Fixed+DVMT=Total Vid. Mem.
Select a setting in which you have a Total Video Memory of 64MB,.... FIXED Memory should always be ZERO. (until unless you have more than 512MB RAM),
you can also increase the total gfx mem. to 128MB if your M/B supports it.(most probably it would, but stick to 64MB, as most of latest game would run fine in this setting).
To free up more RAM for gaming, close the AntiVirus app., FireWall (third party ones,like ZoneAlarm), SpyWare progs. (like Widows Defender). or create a separate acc. for gaming & disable all these progs. from "msconfig".
ASUS K53SV SX520D + BF3
