Old 23-08-2006, 12:07 PM   #1 (permalink)
Default ASUS Notebooks
Hi,
I am looking for notebook with an excellent screen for watching movies and gaming. It should serve my primary purpose of programming as well. I have collected some configuration details on ASUS F3JM Notebook. But I am not sure about the same. It would be great if you can confirm my understanding your review comments are greatly appreciated.
CPU & Chipset
Intel Centrino Core Duo T2400 1.83 G Hz
Mobile Intel 945 PM Express Chipset
Storage & Memory
HDD: 80GB SATA 5400 RPM
ODD: DVD Super Multi (DVD-RW)
RAM: 2 GB DDR2 667 (2X1024)
Video
NVDIA GeForce Go 7300 with 128MB VRAM
15.4" WXGA+
Glare Type - Color-Shine, Crystal-Shine TFT LCD
250 nits high brightness.
ASUS Splendid Video Intelligent Engine Technology
TV Out (S-Video composite), D-sub Port and DVI Ports
1.3M Megabyte Pixels Video Camera
Audio
Integrated Intel High Definition compliant Audio with 3D effect full duplex
SoundBlaster Pro Compatible (24 Bit)
Built-in speaker and microphone With S/P-DIF Port
Audio-DJ for play/pause, stop, forward, rewind
Ports/Connectivity
1 x VGA port/Mini D-sub 15-pin for external monitor
1 x Microphone-in jack
1 x RJ11 Modem jack for phone line
1 x RJ45 LAN Jack for LAN insert
3 x USB 2.0 ports,
1 x IEEE 1394 port
1 x TV Out (S-Video composite)
1 x Express Card
1 x SIR-115.2Kbps supported
1 x Infrared Port
1 X Headphone jack with S/P-DIF
1 x DVI Port
1 x Bluetooth V2.0+EDR
Card Reader: MMC/ SD/ Mini-SD/Memory Stick/ MS Pro/ MS-Duo/MS-Pro-Duo
Battery : Li-Ion 6 cells: 4800mAh, 3S2P, 53.28 WHrs
Thanks
Shiva
shiva.kb is offline
Old 23-08-2006, 12:26 PM   #2 (permalink)
Default Re: ASUS Notebooks
a geforce 7300gs won't do for gaming.
get a dell with atleast 7600/7800/7900 series card.
akshayt is offline
Old 23-08-2006, 02:57 PM   #3 (permalink)
Laptoping
Sourabh's Avatar
Check out Asus w3j for gaming. Go7400 and x1300/x1400 are quite entry level and descent at best for their gaming capabilities. the x1600 and 14" widescreen on the w3j should suffice your needs. If you are looking for an extremely high end best-of-the-best config you can get configure Dell Inspiron 9400 (17" widescreen) with Go 7900GS.
Sourabh is offline
- by c4u
