well , I need to clean my Dvd-rw , I heard about CD cleaner , but no DVD-cleaner . I phoned to my computer shop they said Frontech CD drive cleaner CD is Rs 80 . is that ok ?
<< By CD cleaner I meant to say it is a cd with have a tiny brush associated with it and nothing else , when it spins @ CD drive , the head gets clean and it is a CD not a liquid >>
yes i think it is ok and is the best method to clean lens , i myself is using a cd lens cleaner , but make sure one thing the brush shud not be too rough, it shud be soft otherwise instead of cleaning it will further damage ur lens
signature??? :???: Let Me Think About It!!!:-D
I Got a WRITEX DVD-CLEANER for Rs 80, 3 months ago!
was specifically searching for that,all it turned was the same Brush cleaning mechanism(but had abt 6 small brushes instead of the default 2 forthe CD-cleaners) ,but the medium was DVD along with some good sound tracks thrown in!
