Old 22-08-2006, 10:43 AM   #1 (permalink)
Welcome To The Jungle
sysfilez's Avatar
Question Lan Connection
How can i speed up my lan connection? when ever i am transfering data over the local network its very slow. pls suggest ideas.
Me n My Canon EOS 350D with EF 50mm f1.8
sysfilez is offline
Old 22-08-2006, 01:13 PM   #2 (permalink)
Beware of the innocent
ilugd's Avatar
Default Re: Lan Connection
open the lan card properties from device manager and go to advanced tab. Select 'Link speed & duplex' to 10 Mbps or above. Basically that should marginally help you. But, make sure your hdd is not the bottleneck.
Life is too short. Have fun.
ilugd is offline
Old 22-08-2006, 01:28 PM   #3 (permalink)
-The BlacKCoaT Operative-
Rollercoaster's Avatar
^same suggestion
BTW did it used to be faster earlier?? Post ur transfer speed and 'connected at' speed.
Rollercoaster is offline
Old 23-08-2006, 08:40 AM   #4 (permalink)
nach p's Avatar
data transfer speed depends upon distance between computers ,cable used for lan and somwhat on u r ethernet card.
"UNIX is basically a simple operating system, but you have to be a genius to understand the simplicity."
-Dennis Ritchie
nach p is offline
Old 29-08-2006, 03:51 PM   #5 (permalink)
Post Re: Lan Connection
see if you are using a hub to connect your lan( which is quite obvious )then there is no way to make your lan connection fast. becasue hub first broadcast the data over the network n checks every machine for correct delievery which cause a problem n data transfer will be slow.
speedrider - The ultimate
speedrider_100 is offline
Old 12-01-2007, 03:48 PM   #6 (permalink)
24online's Avatar
9-10 MBps speed between two pc through ethernet switch...
and less speed on network of ISP between two pc through lan messenger softwares...
**#(o)#**
24online is offline
- by c4u
