Old 21-08-2006, 01:03 PM   #1 (permalink)
Call me Sumit
esumitkumar's Avatar
Default any electric charger for ZEN Microphoto 8 GB ?
hi
since my USB port isnt working....so i have decided to buy electric charger for Zen Micro photo ..8 GB..but I think its very costly arnd 3-3.5 K
http://in.creative.com/products/prod...ct=11711&nav=1
Can anybody suggest some JUGAAD or cheap charger which can charge this ZEN from power mains ?
TIA
Sumit
esumitkumar is offline
Old 21-08-2006, 04:30 PM   #2 (permalink)
Sup' dude, Sup'
Default Re: any electric charger for ZEN Microphoto 8 GB ?
Hi Sumit,
Go for authentic chargers though they are expensive. One high voltage output from low quality charger is enough to destroy your player.
ambandla is offline
Old 22-08-2006, 01:37 PM   #3 (permalink)
-The BlacKCoaT Operative-
Rollercoaster's Avatar
well if u can find the right pins and the right voltage then u can rig one up. but u have to be comfertable with soldering n stuff.
safer to get a readymade one...
Rollercoaster is offline
Old 22-08-2006, 02:37 PM   #4 (permalink)
Call me Sumit
thnx guys
