| Forum |
#1 (permalink) |
x2 4200+ asus nforce am2 socket xfx geforce 7300gt 1.5 gb ddr2 533mhz hynix 160gb sata seagate the other config is conroe(core 2 duo) e6300 1.86ghz asus nforce chipset mobo rest is same.since there is a little difference between the two,i wanted to know which is better? and could anyone advise me on ram.ddr2 800mhz is not in india.can i install lesser ram (ddr2533) now and go for 800mhz ddr2 later?will the two work in sync? |
#2 (permalink) |
The conroe is much better and comsumes less power. so good for over-clocking.with such a good gaming rig why are you opting for a 7300gt. I suggest you to for a minimum 7600gt or a 7900gt.
"Imagination is more important than knowledge. For knowledge is limited, whereas imagination embraces the entire world, stimulating progress, giving birth to evolution." ~ Albert Einstein |
#3 (permalink) |
right now? i would go with the stable and reliable x2 939 module du to the fact that its been around for a while and all the bugs are worked out of it and there are mobos available which do not cost 10000 big ones
(\__/) (='.'=)This is Bunny. Copy and paste bunny into your (")_(")signature to help him gain world domination. |
#4 (permalink) |
If you are getting for gaming, get a good graphic card, else even a X6800 is crap.
Get atleast 7600GT or 7900GT. After that, if you can a good overclocking motherboard for Core 2 Duo, get it else get X2 3800 + Asus A8N E(939) You may need to only use 2 modules with AMD systems, else problems |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
