Old 19-08-2006, 06:10 PM   #1 (permalink)
Default System restarts after loading windows
i have p-3 1Ghz pc at office, i changed it mobo recently i.s 810e chipset.
i formatted c: & d: due to some problems.
i installed Winxp, & FOR THE 1ST START
but as soon as win starts after 20=30 sec sys restarts or stops responding showing an error message SYSTEM HAS JUST NOW BEEN RECOVERED FROM A SERIOUS ERROR.
I EVEN TRIED SAFE MODE BUT NO CHANGE. i reinstalled winxp but still same probe, i think its some hardware probe,my mobo is in warranty
...guys plz help me
Intel Pentium triple3core 5.5Ghz intel original D502 GCCL Mobo 50 Gb DDR-4RajaPathar 2048Mhz 40 TBHDD EX12500XFX2GbDisplay SonyBlueRay+/-RW80.5GB
return_of_vengeance is offline
Old 19-08-2006, 07:31 PM   #2 (permalink)
SE><IE
Posts: n/a
Default Re: System restarts after loading windows
Enter the BIOS and load optimised defaults, maybe you messed up a bit with the bios
Old 20-08-2006, 01:30 AM   #3 (permalink)
i tried that also but no results...ooops...
Old 20-08-2006, 08:45 AM   #4 (permalink)
d
yes it is a problem with either the RAM or the mobo(northbridge) .... mostly the former....perhaps you could change RAM modules and try? or install Win98SE or something...?
The torquemaster rules.
d is offline
Old 21-08-2006, 01:16 AM   #5 (permalink)
i tried installing win 98 se it has same probe , windows doesnt load after bios....
i dunno abt ram or mobo....my frnds telling that ram is ok.
Old 21-08-2006, 02:02 AM   #6 (permalink)
Dreaming Future
kin.vachhani's Avatar
Question Re: System restarts after loading windows
Check if there is a memory dumping or not..........
kin.vachhani is offline
Old 21-08-2006, 02:20 AM   #7 (permalink)
GaurishSharma.com
gary4gar's Avatar
try checking ram with memtest86
also post the error msg. for this read the report which it tries to send.
then only we could figure out whats wrong
gary4gar is offline
Old 21-08-2006, 11:31 AM   #8 (permalink)
Dreaming Future
Hey foks..I wnt o know is there any tools for checking ram dumping ????
World without Computer is like a man without Brain.....
Old 23-08-2006, 12:36 AM   #9 (permalink)
ya dere's one i know but i m not sure abt it, its cyberlat ram cleaner or some other from cyberlat
Old 20-04-2008, 11:28 AM   #10 (permalink)
Hi,
Having seen the entire chain of blogs, I would suggest the following
1) If it is 80GB HDD, DVDRW, Macro ATX board with less than 300W power supply,
then it is a very good reason for PC to restart, this happens when all the three
resources are engaged with bigger applications.
2) Also check for temperature issues.
3) If it is already 300W power supply, then check the power supply using multimeter in
all the ports & also for fan issues.
Try changing the power supply to more than 300w
Bye.
White rabbit is offline
Old 20-04-2008, 03:16 PM   #11 (permalink)
Just a techno junkie
roxysmile's Avatar
+1 to white rabbit
please check if any ram pins are faulty(out souldered)
if they r faulty then the data would lag , creating restart
roxysmile is offline
