Old 19-08-2006, 05:05 PM   #1 (permalink)
Default Cant Find DVD/CD RW drive
hi frnds, just now i bought LG DVD Combo.
it sed to work properly, but now a daz , my os cant detect it.
Even Bios fails to detect it.
I reconnected its cable (both power cable & data cable) but the problem is not solved, i guess its hardware problem.... its all on you guys.i need ur help.
Intel Pentium triple3core 5.5Ghz intel original D502 GCCL Mobo 50 Gb DDR-4RajaPathar 2048Mhz 40 TBHDD EX12500XFX2GbDisplay SonyBlueRay+/-RW80.5GB
return_of_vengeance is offline
Old 19-08-2006, 07:37 PM   #2 (permalink)
SE><IE
Posts: n/a
Default Re: Cant Find DVD/CD RW drive
Did you try changing the cable? maybe the cable is faulty. The similar thing happened to me. Ma floppy drive always said "please enter a disk" (kinda similar) I bought a new floppy drive but the problem still persisted, then when I completly overhauled ma rig but the problem still persisted. It was the faulty cable.
Old 20-08-2006, 03:00 AM   #3 (permalink)
Unhappy Re: Cant Find DVD/CD RW drive
its not fault with cables, as the other cdRW drive works perfectly with the same cable, even interchanged their cables....
Old 20-08-2006, 04:32 PM   #4 (permalink)
SE><IE
Posts: n/a
Did you try using that DVD drive on any other mobo. maybe your drive went for a ride. try connecting at some of your friend's PC
Old 21-08-2006, 12:44 AM   #5 (permalink)
ya the probe is solved, it was the fault with my DVD combo i tested it on other device & got it....thnx for ur help.
Old 21-08-2006, 11:17 PM   #6 (permalink)
SE><IE
Posts: n/a
np
