| Forum |
#1 (permalink) |
I am in Chennai and I have chosen the following upgrade 512MB DDR2 RAM Samsung Spinpoint HD160JJ 160GB MSI K8N Neo FSR I am confused for the selection of two components: 1. Is the AMD Athlon64 3000+ better or should I go for the AMD Athlon64 3800+? Give the price difference also. 2. What graphics card should I choose? I want to play relatively high end games like NFS MW, FIFA 06, HL2, DOOM3, comfortably. For this, should I choose the ATI 9600XT, Geforce 5700, Geforce 6600, or the Geforce 7300? Give the link for the prices also, please. |
#2 (permalink) |
-The BlacKCoaT Operative-
well keep in mind that at the cost of Amd 3000+ which runs at 1.8GHZ it can be oced to 2.6ghz thus giving u a much better price/performance ratio...
i have done in to my pc and it is phinominal !!!
-------------------------------------------- Holding my last breath, safe inside myself..... -------------------------------------------- I dont use my computer. I misuse it- रोलरकोस्टर |
#3 (permalink) |
SNIST Screamer !!
3800+ is a much better proc ...but it costs a lot more
3000+ costs abt... 5.5k 3800+ abt... 15k and for the GFX card ...the one which can play all the mentioned games at the lowest price is Geforce 6600gt 128mb costs abt 7.5k
http://snistscreamers.blogspot.com/ http://insidevoidmain.blogspot.com/ SNIST-Blog: the Voice of SNIST... http://www.snistblog.com/ |
#4 (permalink) |
Last quote I got was 9k for 3800+ and 6.5k got 6600GT (XFX). But i think u should go for 7600GT which is for 11k and is twice as fast as 6600GT. 3000+ is avilable for around 4.5k-5k. But since its ur new comp so i think opt for 3800+ and 7600GT (if ur budget permits).
#5 (permalink) | |
In case of GC you will get better 7xx series cards for less.
V.Prem Kumar |
#6 (permalink) |
The only difference between AMD 64 3000 and 3800 is the difference in speed, from 1.8GHz to 2.4GHz. This means that if you are somehow able to raise the CPU speed to 2.4GHz then your CPU is more or less as fast as the latter(the only minor differences will be on the account of usage of memory dividers while overclocking etc). This is practically a very very possible aim and commonly achievable. Current AMD 64 CPU's are bases on the Venice core architecture and it is common to go as high as upto 2.6-2.8GHz. 2.4GHz is almost a garuntee. Another important thing is that even if you get the AMD 64 3800, there won't be much speed difference after overclocking both CPUs and another thing is that the AMD 64 3800 need not overclock more than the 3000. 3000 in turn is a lot cheaper and gives you decent performance in todays' games and can play most/all games at maxed out settings if you have that kind of graphic card and have your CPU at 2.2-2.5GHz speed.
Since your budget isn't very high, it is advisable to go in for AMD 64 3000 as for gaming the graphic card is basically the main thing which counts. However you need to couple your CPU with a motherboard that supports overclocking and preferably with a good cooling solution as well to get maximum overclocks. It is always better to go in for overclocker's RAM as well. But since you don't have the budget for that expensive RAM and cooling at the moment, just go in for a good overclocker's motherboard. In the value section, Asus A8N E should more or less be your best bet. It costs around 5.5k and a second hand one may be available around 4.5-5k. Make sure that you only get the Rev 2 or higher in case you go in for a second hand one. AMD 64 3000 should cost around 3.5-4k. Making it a total of 9k+. In the price range of 8.5k, you do get a CPU which I would definitely take over the AMD 64 3800. This is the X2 3800 which is a dual core CPU, and has 2 cores each of 2GHz. Now you will obviously think that 2 cores of 2GHz > 1 core even @ 2.8GHz. However this need not be true. Most current games don't make full use of dual cores. As a result for most games the X2 3800 will perform close to a single AMD 64 3200 @ 2GHz. However X2 3800 is surely any day better for multitasking, but that is not your priority anyway. Some current games do show a performance difference with X2 3800, which may be in the form of 10-20% faster FPS(frames per second, or the speed in layman terms), but justifying the extra price for that much performance difference whien money is a very tight constraint, doesn't make it good enough. Some games can show a increase of even 30% performance in terms of minimum FPS. This means that when the game is at aa very CPU intensive stage, a single core CPU may be slow at those moments but the dual core will be able to manage a much better position. To top it, X2 3800 can be overclocked as well, if you are lucky then even upto 3GHz, but only if you are very very lucky and with after market cooling. For you the practical maybe 2.2-2.7 or so, or maybe 2.4 or so, depending upon your luck on the peice you get. Another plus is that for the upcoming games of the near future it will be much better. But if you keep in mindthat most current games will run fine with the single core CPU, and after overclocking it, it won't perform as bad even in some CPU intensive titles and adding to it the fact that you are getting a good overclocker motherboard and a much better graphic card, it according to me becomes a much more recommended solution as compared to the dual core for your budget. AMD 64 3000 + 7600GT > X2 3800+ 7600GS. It is true that at lower resolutions which these cards offer especially even the 7600GT in the near future, the CPU becomes more prominent. But a the moment the 7600GT is not that bad a card and will let you play your game fine at 10X7 Med-Max. This certainly does make the AMD 64 3000+Asus A8N E+7600GT(or X1800GTO) your best bet. However do keep in mind to power this system with atleast 1GB ram(try to stick to transcend, this mobo doesn't support corsair value select atleast back then). To make full use of this system you need 2GB ram. Get the Seagate Sata II NCQ 250GB for Rs.3800 or so. Get atleast a good quality 400-450 watts power supply to power this system. These are socket 939 motherboards that I am talking of and only support DDR memory. Another alternative you have is the Intel Core 2 Duo E6300 + Asrock 775 + DDR 2 ram, but that alternative may be a bit more pricy that the single core and the asrock doesn't let you overclock much either, but it is still better than the single core combination and maybe equivalent or almost as good or maybe even better than the AMD dual core depending upon what overclock you are able to get with the AMD dual core. The intel is 2 X 1.86GHz and may reach upto 2.1GHz. But since your budget is really tight, it may not be advisable to go for this. Also, keep in mind that with 512mb RAM you will have trouble playing todays games like BF2, FEAR, GRAW, and almost all decent games out by now, even if you have the fastest CPU and GPU in the world. You need to get atleast 1GB and for full potential exploitation even 2GB of RAM. Last edited by akshayt; 19-08-2006 at 09:41 AM. |
#7 (permalink) | |
Manchester United
3800+ X2 ~ Rs.8400 Source : www.deltapage.com.
PS3-Ipod Touch 4G-Samsung Galaxy Ace-Sapphire HD 6870 Twin Frozer-Creative Zen
#8 (permalink) |
SNIST Screamer !!
oopsy srryy ...my prices were 6 months old..they did come down a thug now ...srry again
| Bookmarks |
| Thread Tools | |
| Display Modes | |
