| Forum |
#1 (permalink) |
to start my pc i have to press the switch 15 - 20 times (turning it off n on - the UPS).. while the hdd red light glows n goes off.. after 15 -20 times doing this it finally starts normally.. could any 1 tell me the problem with my comp.. is it a PSU(Power Supply) Problem??? or sumthing wrong with my main board.. btw specs.. kobian Mercury mainboard KVM266PM AMD Athlon Xp 2000+ 128MB x2 266mhz RAM one more thing.. can this happen due to the Mainboard battery? |
#3 (permalink) |
try running ur PC directly from the mains supply, i mean dont use ur UPS , if ur PC is still not running then there must b a problem in ur PSU unit
signature??? |
#4 (permalink) |
bang bang!
It happens with me also. My pc starts after 2-3 trys and its coz of that cheap, bad performing Odessys SMPS and it started after my vendor change the SMPS after some prob. So I think its SMPS prob. only.
#6 (permalink) | |
signature??? |
#7 (permalink) |
Get ur SMPS changed
AMD Athlon64 2800+|ASUS K8N-VM|2GB DDR400|Corsair VX450|Seagate ST3500320AS|Samsung SV0411N|LG 22xDVDRW|LG 700S|APC ES500|Altec Lancing AVS300|Logitech MX3200|Logitech QuickCam Connect|Philips SHM6105 |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
