| Forum |
#1 (permalink) |
Just Do It
Need your help, as to which I should choose. Please also mention the latest config I can get. I dont require a mouse and a keyboard. It is for personal use[home]. Would love to have monitor,graphics, bluetooth, DVD RW & CR RW,etc in it. Hope Bangaloreans will post in their responses as to whereabouts for purchase. It should be the LATEST and budget can go upto Rs.30,000 Post your opinions ...... Last edited by Charley; 18-08-2006 at 10:40 PM. |
#2 (permalink) |
-The BlacKCoaT Operative-
well it all depends on ur usage. u havent posted the main area of work u will put the machine too
-------------------------------------------- Holding my last breath, safe inside myself..... -------------------------------------------- I dont use my computer. I misuse it- रोलरकोस्टर |
#3 (permalink) |
If u r familiar with computer components (or u know someone who has decent knowledge about PC) only then u should go for assembled PC otherwise there is big chance that u will taken for a ride by the assembler. In such scenarios Branded PC r better bet. But luking at the budget and ur need for latest, assembled PC r the only choice since branded PCs will cost u more for the latest stuff u r luking for. U have to balance between both.
As for the laptop, assuming u have budget of around 35k, I suggest u go for acer or then Zenith. But consider increasing the budget a bit more so that u can touch Dell (which r better value in lower performance range). |
#4 (permalink) |
For laptops go for a reputed brand. If you can increase your budget by five or seven you can get a decent machine.
Welcome to the desert of the Real... " ಡ್. ರಾಜ ಅಭಿಮಾನಿ " |
#6 (permalink) | |||
Just Do It
Whats your opinion for the latest config ? Quote:
#11 (permalink) |
Welcome To The Jungle
nothing comes close to assembled pcs. u can get the best stuff u want and fit it into ur pc. compaq is all scrap they have poor service.
Me n My Canon EOS 350D with EF 50mm f1.8 |
#12 (permalink) |
well i am using a compaq pc for almost 3 years(will complete three years on 29th sept) and all the problems i have got are software based.
my dealer got me an genuine win xp pro for free. the hardware support is the best from their dealer which is near to where i live. i have just changed my HDD amd RAM coz i wanted more memory.... but as far as i see branded pcs give better support and peace of mind... if something goes bad in the assembled one the assembler will only blame u coz u are the one to give him instrutions.... as for laptops my uncle uses a compaq presario laptop for 6 months now and being a student of computer engg. i would advise u to not go for a assembled laptop coz laptops are harder to assemble and have a high failure rate... the decision is upon u SO go for branded pc and be HAPPY HAVE A NICE DAY Last edited by THE PHENOM; 07-09-2006 at 12:42 AM. |
#13 (permalink) | |
GUNNING DOWN TEAMS
With budget u ahev and bit of gaming...u can go in for assembled PC.... if ur work requires PC work then u as well buy laptop.......but if for hoem use ...better stick to PC..assembled oen is better.....
The moment U stop learning ......u stop improving |
#14 (permalink) |
TechTin.com
as per ur budget..u sud go for assembled.
and forgot laptop if u need for home use.. with gud confrigation.
www.9zap.com/forums -> Indian Webmaster Forum whost.in - Web Hosting Offers thinkdigit.com/forum/showthread.php?t=109137 TechTin.com |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
