Old 18-08-2006, 06:42 PM   #1 (permalink)
ionicsachin's Avatar
Default The USB cable...
I have an easy share camera of my friend. But i forgot to take the USB cable. Will any other camera's USB cable work to transfer the data...
My first song
http://rapidshare.com/files/128849730/Sachin_-_In_My_Dreams.mp3
http://cid-e2d4f861e716a7fe.skydrive.live.com/self.aspx/.Public/Sachin%20-%20In%20My%20Dreams.mp3
ionicsachin is offline
Old 18-08-2006, 06:54 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: The USB cable...
it its the same kind why wouldnt it work ?
Harsh J
www.harshj.com
QwertyManiac is offline
Old 18-08-2006, 07:51 PM   #3 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
basically any cable tht fits in the USB slot will work
vijay_7287 is offline
Old 19-08-2006, 03:29 AM   #4 (permalink)
please specify your camera?? if its of frontech/intel any usb cable that fits in that pin will work, but u got to have its driver cd...
Intel Pentium triple3core 5.5Ghz intel original D502 GCCL Mobo 50 Gb DDR-4RajaPathar 2048Mhz 40 TBHDD EX12500XFX2GbDisplay SonyBlueRay+/-RW80.5GB
return_of_vengeance is offline
Old 20-08-2006, 12:05 PM   #5 (permalink)
d
well.. any USB cable will work, but it has to be matching on the camera end... and you have the drivers..
The torquemaster rules.
d is offline
