Old 18-08-2006, 06:27 PM   #1 (permalink)
Default is single core 3800+ processor better than a 3.2 ghz intel pro???
is single core 3800+ processor better than a 3.2 ghz intel pro???plzz reply guys!!!
killzone is offline
Old 18-08-2006, 06:59 PM   #2 (permalink)
samrulez's Avatar
Default Re: is single core 3800+ processor better than a 3.2 ghz intel pro???
Yes it is.....infact the 3000+ comes in competition with the 3GHz procey...So u very well know where the best Athlon64 would stand!!
Sam Rulez
samrulez is offline
Old 18-08-2006, 10:16 PM   #3 (permalink)
Without a doubt the 3800+ is better than Intel 3.2 GHz.
But if you're considering a 3800+ single core, I'd advise you to spend a little more and get the X2 3800+. Cost difference is negligible.
drvarunmehta is offline
Old 19-08-2006, 09:45 AM   #4 (permalink)
Rather AMD 64 3000 an oc it u[wards of 2.4GHz from 1.8GHz. or get X2 3800
What is your usage and which Intel CPU are you talking about.
eg: Soem Intel CPUs @ 3.0GHz may be better than AMD 64 3500 for Photoshop. some AMD 64 3200 may be better than some Intel 3.6/3.8GHz for some games. Which Intel CPU are you talking about, there are many 3.2. What usage are you talking of?
akshayt is offline
Old 19-08-2006, 07:40 PM   #5 (permalink)
SE><IE
Posts: n/a
Well AMD's processors lack in rw number crunching but they sure come out in other(read most) arenas. Ma Athlon 64 3500+ is actually 2.21 Ghz but its nowhere below Intel's 3.8Ghz. Don't go with the no.s baby.
Old 20-08-2006, 09:24 AM   #6 (permalink)
for most purposes intel 3.8 should be better in terms of raw power.
akshayt is offline
Old 20-08-2006, 03:50 PM   #7 (permalink)
deathvirus_me's Avatar
Depends on ur usage ... in gaming a 3200+ would compete with a 3.4 GHz Intel ... but if ur more concerned with encoding , decoding etc. etc. then the 3.4GHz one will have a slight edge .. but considering the price , if u do intend to get a single core , then a 3500+ (keep aside the 3800+) will beat the 3.2 GHz easily ... 3500+ at stock competes with a 3.6 GHz easily ...
deathvirus_me is offline
Old 20-08-2006, 06:46 PM   #8 (permalink)
For most purposes, I said. Other than gaming in most things like encoding, decoding, graphics, multitasking etc, won't Intel have a clear lead.
akshayt is offline
