| Forum |
#1 (permalink) |
D PrankMaster
so is there a viewing hour life duration for lcd's too???
My Rig: AMD Phenom II 550BE | Gigabyte GA880GM-USB3| Sapphire HD6850 | 2x4GB Corsair Vengeance DDR3 1600Mhz | 2x500GB Seagate HDD | Silverstone Strider 500W | Alteclansing Octane 7 | Microsoft Natural Ergonomic 4000 | Logitech MX518 | Rantopad H1 | APC 0.6KVA My Gadgets: Nikon D3100 | PSP1000 | XBOX360 20GB | Sansa Clip+ | Soundmagic PL50 | Meelectronics M9BK |
#2 (permalink) |
The Blessed one
i dont know if this can be helpful,but For what purpose are u going to use that 17" LCd.
If you plan to use for gaming,watching movies on PC, CRT desktops(the bulbk ones which majority use today) are best because you can see some ghost like shadows on LCD. |
#3 (permalink) |
King of my own Castle
Samsung SyncMaster 740N best in 17" inches category. Rated Best performance by PC world This month.
Hmm yes LCD's sure have life Span which is roughly 25000 to 30000 hours. considering they are on for 3 to 4 years 24/7. Under same scanario CRT has life span of 12000 to 15000 Hours. So clearly LCD's have more life Span. Go for it.The newer ones dont have much lagging effect ...almost one in Movies or Games. |
#6 (permalink) |
D PrankMaster
well i'll be watching a lots of movies and play a lots of games on it...
i m considering acer coz it costs just 10.5k for 17" and has a response time of 8ms.. pretty good, is'nt it???
#7 (permalink) |
Sup' dude, Sup'
For Extreme Gaming, CRT is better than LCD. go for Syncmaster/Acer CRT.
You can easily get a 19" CRT for this price. CRT Monitors: Pros: Multisync Capable High Refresh Rates Color Clarity and Depth Cons: Very Heavy and Large Use Large Amounts of Energy Generate Excess Heat LCD Monitors: Pros: Smaller and Lighter Energy Efficient Causes Less Eye Fatigue Cons: Blurry Images Outside Native Resolution Motion Blur on Fast Moving Images Come Models Have Reduced Color Clarity As you can see, LCD is better than CRT in terms of space. If clarity is your prime req., go for CRT.
Introducing Windows Vista 2.0. Check it out at http://www.apple.com/macosx/leopard/index.html Last edited by ambandla; 18-08-2006 at 01:24 PM. Reason: Automerged Doublepost |
#8 (permalink) |
Those days are long gone when CRT's were better than LCD's for gaming. The new breed of LCD's feature really low response time with no ghosting or blurring whatsoever. I'm using a LCD and I find gaming to be far better than on my old CRT. Running games outside the native res dosn't seem to affect quality much either.
#9 (permalink) |
D PrankMaster
ya even i did'nt face prob with ma laptops lcd...
well, is 8ms good enough???
| Bookmarks |
| Thread Tools | |
| Display Modes | |
