Old 17-08-2006, 08:56 PM   #1 (permalink)
Angry Unable to find X2 4800
i am not able to find a x2 4800+ ... no dealer is having it here
all have x2 4200+ ... which i dont want
can somebody pls help
vinyas is offline
Old 17-08-2006, 09:22 PM   #2 (permalink)
gooby pls
Third Eye's Avatar
Default Re: i am not able for find
where do you live man.
Third Eye is offline
Old 18-08-2006, 11:10 AM   #3 (permalink)
currently @ bangalore
vinyas is offline
Old 18-08-2006, 12:07 PM   #4 (permalink)
U will have to wait atleast till mid-september. I had talk with AMD guys in Delhi who says that even X2 4200+ will not be easily available (after price reduction) till late August.
monkey is offline
Old 18-08-2006, 09:33 PM   #5 (permalink)
i am able to find x2 4200+ damn easlity here
check this :
http://www.computerwarehousepricelis...list.asp?ctg=1
vinyas is offline
Old 19-08-2006, 09:48 AM   #6 (permalink)
Default Re: Unable to find X2 4800
You will never find the X2 4800 again. It has been discontinued. Either X2 4600 or X2 5000.
BTW get E6300 from Intel instead if you have the moolah.
Else get the X2 4200 and a good cooling solution and make the AMD to 5500+ speeds, or atleast 4800+ speeds.
akshayt is offline
Old 19-08-2006, 09:14 PM   #7 (permalink)
yeah i know ...
planning to get in imported thru my cousin who lives in singapore
hope i find one thre
vinyas is offline
Old 20-08-2006, 08:55 AM   #8 (permalink)
somebody stated 14.5k in the other thread
akshayt is offline
Old 20-08-2006, 09:11 PM   #9 (permalink)
Unhappy Re: Unable to find X2 4800
akshayt ... i know that ...
i am not to find a dealer will supply me for that price
hope somebody can help
vinyas is offline
Old 23-08-2006, 04:00 PM   #10 (permalink)
jz2linkinpark's Avatar
what you are talking about?
e6400(NOT E6300) costs about 7500 bucks less than X2 4400+ over here so how can you say get the X2 4600 or X2 5000 and then say that if he's got moolah get the e6300?
Is e6300 more costly than the X2 4400 and higher in india?
(its confusing,i know)
(\__/)
(='.'=)This is Bunny. Copy and paste bunny into your
(")_(")signature to help him gain world domination.
jz2linkinpark is offline
Old 23-08-2006, 04:47 PM   #11 (permalink)
Resident Weapons Expert
zombie's Avatar
I suggest you opt for a Windsor (AM2) core AMD X2 4000+ with 2MB L2 cache. Couple it with a decent mobo like Asus M2N32-SLI Deluxe and load it up with decent DDR2 PC6400 (800 MHz) RAM and you are ready to rock. Personally I think 4800+ wont be any good with 2MB cache. And no point in sticking with older 939 pins as future belongs to DDR2. And in case you want to opt for a Conroe, wait for couple of months so that kick-ass mobos are out in the market.
Stalk, Strike, Survive.
zombie is offline
Old 23-08-2006, 05:09 PM   #12 (permalink)
deathvirus_me's Avatar
DDR2 has no real performance diff. ... and infact , the better scores are in favour of DDR mem.
deathvirus_me is offline
Old 23-08-2006, 07:26 PM   #13 (permalink)
Reviewerus Prolificus
Originally Posted by zombie
I suggest you opt for a Windsor (AM2) core AMD X2 4000+ with 2MB L2 cache. Couple it with a decent mobo like Asus M2N32-SLI Deluxe and load it up with decent DDR2 PC6400 (800 MHz) RAM and you are ready to rock. Personally I think 4800+ wont be any good with 1MB cache. And no point in sticking with older 939 pins as future belongs to DDR2. And in case you want to opt for a Conroe, wait for couple of months so that kick-ass mobos are out in the market.
The 4800+ with 1 MB? That's 2 MB AFA I know, if you're talking 939. The 1 MB equivalent is the 4600+ (512 x 2), which is also a 2.4 GHz part, codenamed manchester, the 1 x 2 MB part is called Toledo mayte....
^ DDR2 offers greater bandwidth which will be used with time pal... DDR is basically on the road to "kaputdom" with both Intel and AMD adopting DDR2.... Benchy DDR 400 and DDR2 800 and you'll get my drift... DDR2 was sucky in its earlier avatars, not any more...
Lucifer is offline
Old 23-08-2006, 07:55 PM   #14 (permalink)
thnx for the feedback guys ... i want to go for an AMD this time...
with all said ... & done ... AFAIK there is no dealer in idea... who supplies more than x2 4200+ (939).... nor do they tell the prices of higher end X2 like 4600+ or 4800+
wat sort of hardware dealers we have in india ?
check this
http://www.newegg.com/Product/Produc...82E16819103544
X2 4800+ costs 307$ ...converted costs 15k .... which is affordable...
is there anyways u guys can recommend ?
vinyas is offline
Old 24-08-2006, 03:13 PM   #15 (permalink)
zombie's Avatar
Try contacting Delta. Phone 044- 28521607, 28521572, 25857158, 28547698. Email: deltapage@vsnl.com . That should help. Or try contacting AMD directly.
zombie is offline
Old 24-08-2006, 03:19 PM   #16 (permalink)
Why don't you get E6300 instead?
overclocked E6300 >= AMD FX 62 or X2 5000
akshayt is offline
Old 24-08-2006, 05:38 PM   #17 (permalink)
LMAO!! hahahah same here yaar i tried getting a x2 3800 very very limited stocks.. have you tried SP road ?
Sand man is offline
Old 24-08-2006, 05:56 PM   #18 (permalink)
vinyas.......first are u going to overclock????
also u stating price of newegg...man its better u get that frm somone coming frm abroad.........if even that peice is available here 4800+it wont b price below 20k atlest till next year..........presently 3800+ is going for 9-9.5k...when it price shd b ard 7.5-8k.........
i suggest u better get x2 3800+ and than next year go for c2d(which will get cheaper due to quad core entry)......also we all have to shelve money on dx10 cards.........next year.......
also to b frank if u going to shelve 15k on that newegg stuff.....better get c2d(10-11k) and asrock board..........no need to change rams as it supports ddr.........and u will get speed at stock equal to amd 4400+ alsoif in future u think to change rams u dont need to change boards..as it supports ddr2 too
but if u ready to shelve 15k on amd proccy..its better u take am2 one with new board and ddr2 rams......
magnet is offline
Old 24-08-2006, 07:39 PM   #19 (permalink)
asrock is crap, no dual core, no sata, crap overclock = no point buying
akshayt is offline
Old 24-08-2006, 11:47 PM   #20 (permalink)
akshayt if u dont have knowledge dont try to crap ppl
check this
http://www.asrock.com/product/ConRoe945G-DVI.htm
and this is the peice available here vinyas(in india)
http://www.ocworkbench.com/2006/asro...al-VSTA/g1.htm
dude jus search asrock site or jus google ull get your answer..........and akshayt dude ard 95% of computer buyers doesnt overclk...becoz very less knowledge abt it is known....and so do i think is vinyas...since his point buying 4800+ proves that......becoz any good oc if buys a 4800+ will b termed fool..and thats why all runing after 3800+...becoz on oc it will giv performance equal to 5000+
magnet is offline
Old 25-08-2006, 01:10 AM   #21 (permalink)
Infact it does .. try some XMS modules on very tight latencies .. u'll get better CPU scores than with ddr2 800 ... the only reason AMD and Intel is shifting is because ddr2 should be cheaper to produce , and consume less power .. its basically comparing AGP and PCIe , no real diff.
Old 25-08-2006, 09:46 PM   #22 (permalink)
x2 4200+ (939) are damn easily available on Sp Road
also when i went x2 3600+ (am2) had just arrived ... he told its 7.5k....in 15 days time x2 4200+ (Am2) will hit the Bangalore markets !!
vinyas is offline
Old 26-08-2006, 07:05 PM   #23 (permalink)
vinyas.....i seriously say dont go for anything else than 3800+ x2 if u have the rams and board.........in 1 year u will find 4800+ too silly stuff when quad core arrives and dual core price will again fall badly......
magnet is offline
Old 26-08-2006, 07:57 PM   #24 (permalink)
i agree with u bro... also goto understand the indian middle class dont buy a PC every summer ...so i guess we got make use wat we have best at the moment
Got a Mail From Delta Peripherals,Chennai
X2.4800+ is expected by Sept 1st Week
So keeping fingers crossed
vinyas is offline
Old 26-08-2006, 08:00 PM   #25 (permalink)
as u wish dude...ill pray its cheaper than 20k...........
magnet is offline
Old 27-08-2006, 03:05 AM   #26 (permalink)
or better is to go for AMD Athlon 64 X2 4600+ Am2 ... scarifice a bit Processor by less Cache & since it supports DDR II ..will make for loss in performance
vinyas is offline
Old 27-08-2006, 11:26 AM   #27 (permalink)
dude do u have am2 motherboard??????they r not lauch here yet and available in dlhi for ard 8-9k+
magnet is offline
Old 27-08-2006, 11:34 AM   #28 (permalink)
Exclamation Re: Unable to find X2 4800
asus mobo for am2 already available
vinyas is offline
- by c4u
