Old 17-08-2006, 05:53 PM   #1 (permalink)
Unhappy Power Off in just 2 seconds !!!
Hi friends,
config:
AMD 64bit 2800+
Asus M/B
Sony DVD Writer
Sony Combo Drive
APC UPS
Hitachi HDD 80GB
512 400Mhz DDR Ram
This problem comes for the last 2 days... Whenever i switch on the PC, i dont know if the bios loads, the computer shuts (off) in just a sec or 2. What could be the problem? I tried cleaning the RAM and fixing it again. I also tried removing the IDE from HDD, Combo and DVD Writer ( 0 Load ), still the problem persists.
Can anyone please help???
Aakash Shah
aakash is offline
Old 17-08-2006, 06:26 PM   #2 (permalink)
-The BlacKCoaT Operative-
Rollercoaster's Avatar
Default Re: Power Off in just 2 seconds !!!
seems that ur Power switch might be stuck.. check that...
or ur SMPS may be bad.
remove and reinsert the cmos battry too....
Rollercoaster is offline
Old 17-08-2006, 06:39 PM   #3 (permalink)
œ∑´®†¥¨ˆøπåß∂ƒ©˙∆˚¬Ω≈ ç√∫˜
the.kaushik's Avatar
check ur processor fan working or not and in ur mobo bios warnining at hightemp is enabled or not..
Blogging @ http://classictutorials.com
the.kaushik is offline
Old 17-08-2006, 07:41 PM   #4 (permalink)
Hey here is the aks
arunks's Avatar
when problem is solved plz tell us here the solution as i wanna append it to my computer database
arunks is offline
Old 21-08-2006, 01:25 PM   #5 (permalink)
@rollercoaster...
in case its b coz of the power switch that this prob is occuring....then what do you suggest we can do abt it other than replacing it.....
manmay is offline
Old 22-08-2006, 01:34 PM   #6 (permalink)
well if u r an engineer at heart... the open it clean the contacts and re assemble it.
i have to say that for most switches it is gonna be tougher then dissassembling and cleaning and reassembling the whole PC.
DOOD just change it.. what us the big deal. Or cut the wires at the switch and short them to check if the prob is solved or not. at ur own risk, that is.
- by c4u
