Old 16-08-2006, 10:50 PM   #1 (permalink)
Djn
Default More memory or graphic card?
My old P III 800Mhz with 128 Mb Ram on an Intel M/b 810 EA(built in graphics and sound) needs a new monitor. As I would like to add a 17" LCD monitor to it, the display would become 1280 x 1024.
I'm sure the computer will become slower at this display size, so do I add more memory or buy a graphics card?
I intend to buy a new machine in Dec and until then got to make do wih this.
Your suggestions, guys?
Djn is offline
Old 17-08-2006, 02:36 AM   #2 (permalink)
El mooooo
eddie's Avatar
Default Re: How to speedup old computer?
If you are planning to get a new machine in December then my suggestion would be to wait before you buy the new monitor. Till then 19" LCD will become cheaper and you will be able to buy them with your new system...so stick with the current one for a few more months and get a better display rather than going for a 17" right now.
eddie is offline
Old 17-08-2006, 11:51 AM   #3 (permalink)
Djn
The monitor is dead. Took it to the repair shop and found it needs a part which is not available.
17" is enough for me and right now I can't even use the computer, so I might as well buy the new monitor.
Whether it will work properly at 1280x1068 is the key. I don't want to use it at 800x600
Djn is offline
Old 17-08-2006, 11:56 AM   #4 (permalink)
Commander in Chief
QwertyManiac's Avatar
I feel that it'd (LCD) be useless at high resolution with your current onboard graphic chipset!
Harsh J
www.harshj.com
QwertyManiac is offline
Old 17-08-2006, 12:08 PM   #5 (permalink)
-The BlacKCoaT Operative-
Rollercoaster's Avatar
why dont u get a second hand monitor for the timebeing.
ur pc would certianly bend over due to the load...
Rollercoaster is offline
Old 18-08-2006, 01:30 PM   #6 (permalink)
Sup' dude, Sup'
Get a used monitor or a 15" CRT for now. But an LCD with your new PC. You can then use the CRT with your old PIII
who knows, you might even get a 21" LCD for 10k by the end of this year. So, do not hurry. Get ALL new system in December.
ambandla is offline
- by c4u
