Old 16-08-2006, 06:38 PM   #1 (permalink)
tiblu's Avatar
Question Xbox 360 Controller for PC
Hey guys recently i went tolamington road and found that there is a gamepad of xbox 360 for pc it has USB plug priced at 1950, Is it worth buying, cant buy the Xbox 360 atleast a part of it.
tiblu is offline
Old 16-08-2006, 06:46 PM   #2 (permalink)
singh's Avatar
Smile Re: Xbox 360 Controller for PC
well Xbox360 whole is a good hardware for gaming as compared to Playstation 3. Xbox360 will cost you 20,000 rs. whereas Playstation3 is 37,000 rs.
So if u r getting a part of it just for few bucks, i will suggest buy it..... but before buying it check it whether it is working fine on any PC or not or may be sometime it ask for driver to be installed...
singh is offline
Old 16-08-2006, 08:08 PM   #3 (permalink)
Default Re: Xbox 360 Controller for PC
The controller works normally as a USB PC joystick... Very well designed and normal PC games work real nicely... I have one and really like it.
C2D E8400@3.8, P5N32-E SLI, 2GB Cellshock DDR2 1000(4-4-4), 8800 Ultra SLI, 2.7TB storage, CM Stacker 830, TT 1200W, Dell 2005FPW, Lots of Audio HW.
Ch@0s is offline
Old 16-08-2006, 09:13 PM   #4 (permalink)
a_g = JPKN
s18000rpm's Avatar
why spend around 2000 bucks for one piece of XBoX, You can get normal Dual Vibration gamepad for under 500 bucks. (this way u can buy 2 gamepads & play some multiplayer games-- Colin McRae split screen mode ; buy another game title with rest of the money)
But if you dont mind the price TAG go for XBoX gamepads.
I think the price for that gamepad is Higher.
ASUS K53SV SX520D + BF3
s18000rpm is online now
Old 18-08-2006, 04:06 AM   #5 (permalink)
^^Cos dual vibration sticks costing 500 bucks are so bad in ergonomics that you cant play for more than 20 mins without getting an ache in ur hand. Also they don't support XInput... In all newer games, directinput will be replaced by XInput so the 500 rupee gamepad is useless.
Ch@0s is offline
Old 18-08-2006, 08:52 AM   #6 (permalink)
deathvirus_me's Avatar
Hmmm .. didn't ever notice this .. infact the one i have is almost like the xbox controller ..
deathvirus_me is offline
Old 18-08-2006, 09:35 AM   #7 (permalink)
NikhilVerma's Avatar
The one I have cost me like 450 bucks. And I just love it. It never hurt my hand and it's very solid. It's got analog dual sticks. Yeah there might not be any warranty on it. But with a dirt cheap price of 450 who cares about warranty ? I've used my gamepad for like 6 months now ! And it's more than what I expected it to run.
NikhilVerma is offline
Old 18-08-2006, 09:08 PM   #8 (permalink)
tinku dhar's Avatar
hey buddy ... ,
u got the XBOX controller with ya ?????????????
and along with tht u might have got the cd .... plz do gemme the installation of drivers coz... i lost tht and havin prob
tinku dhar is offline
Old 18-08-2006, 10:10 PM   #9 (permalink)
Naah I have a frontech controller ... I've never seen a XBOX controller before although this might help
http://www.google.com/search?sourcei...roller+drivers
Old 18-08-2006, 11:10 PM   #10 (permalink)
-The BlacKCoaT Operative-
Rollercoaster's Avatar
well u can buy logitech wireless rumblepad 2 at the same price... better get it.
Rollercoaster is offline
Old 19-08-2006, 08:09 AM   #11 (permalink)
tinku dhar's Avatar
oooooooooooo ... ,
man its not kinda helpin me ... coz i dunno wich 1 to download and install its ok for now
Old 25-09-2006, 03:16 AM   #12 (permalink)
Is logitech dual action gamepad worth buying? How does it perform?
akkies_2000 is offline
- by c4u
