hi everybody,
my pc configuration as below,
AMD Athlon XP 2600+
nVidia GeForce FX 5200 (128 mb)
256 mb DDR RAM
motherboard : VIA KT400-8235
Now, problem is that my AGP card of nVidia not working properly,
it display properly but make my graphics distorted after working around half hour and makes my screen blinking variantly and slower down my pc a lot, even mouse can not move properly.
before, i had got message "nv4_disp.dll has stopped working normally"
i surf for this problem very much, and do everything as diff. solutions but it was not applied on my problem and not solved.
i installed latest drivers for nVidia Card ( driver version 91.31 which is latest for GeForce), i also installed AMD miniport AGP driver and same the VIA drivers.
somebody says pls check IRC which is shared by another device, i look for that but it is different.
finally, i format my pc, though i got same problem with my AGP card.
Please Help me , if anybody knows about this kind a problem...
thanks in advance.
pritesh
