Old 16-08-2006, 01:32 PM   #1 (permalink)
Default bios doesn't detect my combo drive
hi guys
my bios cant detect my lg combo drive
suggest me a solution
ashok123 is offline
Old 16-08-2006, 01:40 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: bios doesn't detect my combo drive
Well, check cables, etc, and on others comp, if its faulty get it replaced.
Harsh J
www.harshj.com
QwertyManiac is offline
Old 16-08-2006, 09:16 PM   #3 (permalink)
ayush_chh's Avatar
yap, that's the only soln. 4 it.....
eXPerience is what a MAN learn's fROM.....
ayush_chh is offline
Old 16-08-2006, 09:38 PM   #4 (permalink)
nach p's Avatar
check jumper settings ......
"UNIX is basically a simple operating system, but you have to be a genius to understand the simplicity."
-Dennis Ritchie
nach p is offline
Old 16-08-2006, 10:50 PM   #5 (permalink)
deepak_m's Avatar
jumper might be the problem...
deepak_m is offline
- by c4u
