Old 16-08-2006, 11:00 AM   #1 (permalink)
Default pc hangs and reboot!!! :(
hi,
i have a p4 2.4 ghz and intel 845 moherboard..my computer hangs a lot and even restarts automatically...after restart or when i do a manual restart when it freezes i dont get any response from cpu..the monitor led just flickers no beeps to say whether post was ok or not
i even got replaced my SMPS,Moherboard and Ram but the problem is still unsolved please do help me...i m fed up of this problem...plzzzzzzzzzzz help me
sughandhkkde is offline
Old 16-08-2006, 12:52 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: pc hangs and reboot!!! :(
I feel its an overheat issue, check the temp in the bios and see if they are normal (Max around 60)
Harsh J
www.harshj.com
QwertyManiac is offline
Old 16-08-2006, 01:04 PM   #3 (permalink)
gooby pls
Third Eye's Avatar
Always open the cabinet so that cpu couldn't hot.
Third Eye is offline
Old 16-08-2006, 01:17 PM   #4 (permalink)
Commander in Chief
Then dust will eat away all the glory it has remaining.
Harsh J
www.harshj.com
Old 16-08-2006, 01:24 PM   #5 (permalink)
gooby pls
Third Eye's Avatar
No No,i also open my cabinet but i close it in night.
"Thodi si dust sey kya hoga"
Old 26-08-2006, 10:14 AM   #6 (permalink)
i tried opening my cabinet but it still does not work...now my pc even does not boot...monitor light just flickers and pc does not startup...what to do noe
Old 26-08-2006, 11:04 AM   #7 (permalink)
k_blues24's Avatar
I think u have to check Memory module on friends comp.Also remove Memory stick & rub it's golden ends with Eraser 4 that u have 2 open the Cabinet.
If u purchase new memory moduls yhen pls check It's compatibility with ur MB ( go to the MB's Website ) nowadays SDRAM ( DDR 400 - 184 pins r common)
Talk less than u know, Show less than u have ;)
Yesterday is History. Tomorrow is Mystery.
Today is a Gift, that's why it is called as
The PRESENT.
k_blues24 is offline
- by c4u
