Old 15-08-2006, 11:18 PM   #1 (permalink)
Stalker's Avatar
Question soldering an AGP slot??
guys my friend has an HP desktop. his config is
Celeron D 2.0 Ghz
256 mb RAM
intel 865 chipset.
the warranty on the desktop has run out, so he wants to add an agp slot to the mobo. the motherboard has markings (a space with lined silver dots) wherin u it appears that he can fit an agp slot. ( there is 'agp' written on that space which has got the markings)
can u just solder an AGP slot at that position???
will it actually work or does he have to upgrade/change his BIOS??
| C2Q Q6600 G0 | Intel DG33FB | 4 GB Corsair 6400C5G DDR2-800Mhz | XFX 8800GTX | CM Extremepower 600W | 250GB Seagate HDD | Lite-ON 1635S DVD RW | Logitech MX-518 | Zalman RS6F | APC RS 800 |
Stalker is offline
Old 15-08-2006, 11:20 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: soldering an AGP slot??
Thats a crazy thing to do. Yes you will have to update your bios to that one an AGP supporting one, but the risk/cost overall here exceeds that of a new motherboard itself
Harsh J
www.harshj.com
QwertyManiac is offline
Old 15-08-2006, 11:43 PM   #3 (permalink)
Rubik's Uncle!!
Charan's Avatar
There are different versions of mobo's available , few with Gfx slot and few without it. some manufactrers remove the GFX part of the mobo to cutdown the cost.so the same mobo can be available with gfx and without gfx slot, they also remove the circuit required for the gfx slot; which will cut the cost. so if you mobo has the gfx slot missing then it will not have the circuit to drive the gfx part. so forget about soldering the slot. best option ---> buy a new mobo with gfx slot
Charan is online now
Old 16-08-2006, 12:10 AM   #4 (permalink)
Commander in Chief
No, not really true. My old compaq 810 had a marker place for AGP too. But thats because it was made that way, they cant cut a hole in the middle for having no AGP slot can they? Y'maybe right.
Harsh J
www.harshj.com
Old 16-08-2006, 07:25 AM   #5 (permalink)
dOm1naTOr's Avatar
What they gonna cost for just soldering a slot onto a mobo. I dun think. There IS A price difference, so something would be missing.....
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 16-08-2006, 10:12 AM   #6 (permalink)
go_gamez's Avatar
in my opinion better buy a new mobo..
Intel P4 2.47 ghz with 1 MB L2 cache-HIS 845GVM mobo
512 MB DDR RAM .
Gainward 6600 gt golden sample edition(ultra 1960xp)
80 GB Seagate Barracuda 7200 rpm HDD
Sony QW -120A Dual Layer DVD writer.
go_gamez is offline
- by c4u
