Old 15-08-2006, 06:10 PM   #1 (permalink)
Default asus a8ne ultra vs a8ne sli
which of the two is better?i am planning to buy a new pc.since both come at a same price range?is there any difference in the spec?
nfsfan is offline
Old 15-08-2006, 06:31 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: asus a8ne ultra vs a8ne sli
depends on what GCs r u planning to take...
Pathik is offline
Old 15-08-2006, 06:35 PM   #3 (permalink)
samrulez's Avatar
A8N-E is not SLi and is good for overclocking.......
A8N-E Sli is SLi and is good for overclocking even though it is not good as A8N-E......but the diff is very very low,....
But as far as i know A8N-E costs 5.5k and SLi costs 6.5k..
Sam :D Rulez :lol:
samrulez is offline
Old 15-08-2006, 11:58 PM   #4 (permalink)
i am going for a turbocharged xfx geforce 7300.what do u say now?
nfsfan is offline
Old 16-08-2006, 02:46 AM   #5 (permalink)
so u r not going for an sli combination..then why go for an sli baord..take the a8n-e
Even if you plan to go for an sli , 2 7300s would make a crap combination
cyrux is offline
Old 16-08-2006, 07:11 AM   #6 (permalink)
dOm1naTOr's Avatar
I suggest dat u take A8N E along with a 7300GT.
The 73GT scores better than a 6600non GT nd a near to a 6600GT.
GT means a lot more yaarr....
see it to believe:
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 16-08-2006, 11:05 AM   #7 (permalink)
sir i dont understand.cant i install a single 7300gt now and later on go for a higher card when expansion is needed?wont to different nvidia models work on sli? plz help on this.
i have the following config in mind:
->amd a64 3500+/x2 3800+(both socket 939)
->asus a8ne ultra/a8ne sli(does a8ne sli has x16 pcie?...whats the difference in a8ne sli and a8ne sli deluxe)
->1 GB ddr1 400mhz ram + 512 mb ddr 400mhz ram
->160 gb seagate barracuda
->sony dvd writer
->xfx geforce 7300 gt
any suggestions for me.my budget is 28k-34k(for cpu).
and can anyone plz tell the pricing of these cheapest in delhi.....
nfsfan is offline
Old 16-08-2006, 12:40 PM   #8 (permalink)
samrulez's Avatar
Nope u cannot add different cards in SLi they have to be identical.....
X2 7300GT......u cannot add 1 7300GT and 1 7600GT....
Yes u can use one card with the both.....
For the ram..;.
Get 512X2 (SAME model,same memory)
or 1024X2 ''
and put them in dual channel....
Sam :D Rulez :lol:
samrulez is offline
Old 16-08-2006, 01:57 PM   #9 (permalink)
For the ram..;.
or 1024X2 ''
dual channels can be filled only if all the four memeory slots are filled!
nfsfan is offline
Old 16-08-2006, 02:07 PM   #10 (permalink)
deathvirus_me's Avatar
Ahem ?? MMM .. uuhhh ???? Even slots ... either 2 or 4 ...
deathvirus_me is offline
- by c4u
